Question about Kitchen Ranges
Renmore Elite range is locked and control panel is not working.
Last night, I set my oven to cleaning cycle. When I got up this morning, the control panel was not working and the oven is still locked. Help!
  • msgenamorgan Nov 24, 2008
    Thanks for your help!!!
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Sounds as if you blew a high limit thermostat. common to happen afeter a clean cycle, located on the back wall behind the rear panel the thermostat, is a quarter sized disc,parts probably about $50
Posted on Nov 24, 2008
My oven is locked and wont open. it is cold and wont unlock
Hi
Thanks for using FixYa. The locking of the oven is a safety measure while self clean function is activated. Once the oven has completed the cycle & has cooled down, then it will reset the door lock.
If a self clean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition or you were not using the self clean cycle, then, the lock must usually be accessed and moved manually to open the door—
In order to open the door you have to open the control panel and remove the door lock.
Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs.
The door lock is secured by the three screws.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 25, 2009 | Maytag MER5775Q Electric Kitchen Range
F2 and F3 Errors just started on my GE Electric Range
I had to clean the contacts in the control panel to fix my same problem.
Nov 10, 2009 | GE Kitchen Ranges
My GE Spectra gas oven worked fine last night. Today, the oven will not heat. The broiler and the burners work fine, as does the clean feature. But nothing when the oven is turned on.
Are you sure the cleaning process works, because usually when the oven wont work, the clean process wont work. If you are correct, then the problem is most likely the control panel not responding to the bake setting. This will require either a new touch panel or a new control circuit board.
Oct 11, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Oven door won't open
Try pushing in on the door. You also might try cycling the power to the unit at your breaker box.
Oct 09, 2009 | Frigidaire FEF364DQ Electric Kitchen Range
Door won't open after cleaning
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Apr 01, 2009 | GE Kitchen Ranges
GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
Self clean oven door lock will not unlock accidentally pushed clean button, cancelled clean but oven door will not unlock. it's been two days now.... what should i do? tried unplugging unit, that...
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
Sep 09, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore elite oven lock
None of above worked for me. But, gave me a clue. I pressed the Stop/Clear button for apprx 10 sceonds. the "door locked" flashed for 5 seconds and then cleared and the door unlocked. Panel worked fine after that.
Mar 10, 2008 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
