Fellowes p-48c shredder is jammed - Office Equipment & Supplies
    Genius:
  • 2,120 Answers
Lots of soapy water will dissolve jammed paper. Oil the cutter heads afterwards.
Posted on Nov 25, 2008
Can i purchaser the basket only?
For smaller models like this Fellowes and others typically will not have spare parts as it simply isn't worth the while. However it's worth a call to Fellowes. Their number should be on the unit somewhere.
Apr 17, 2016 | Fellowes Powershred P-48C - Shredder
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Shredder stopped working lights come on shredder doersn't not jammed
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Apr 21, 2014 | Fellowes Powershred PS-60 Shredder
My fellowes p 48c is jammed
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and
place upside down. Use a small screwdriver and poke at any compressed paper
wrapped around the blades - can take a while.
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Feb 26, 2014 | Fellowes P48C Cross Cut Shredder with...
Spilled coffee on shredder when it was turned off now it wont power on what to do
If your shredder plug has a fuse I would check that first, it may have blown if you turned it on again while it was wet
What I personally would do is take the shredder part and run it under a tap to clean of any coffee residue then shake it dry before putting it into a warm dry place like an airing cupboard for a 3 or 4 days to ensure it is completely dry before trying it again.
If it still doesnt work
Oct 26, 2013 | Fellowes p-48c cross-cut shredder
My paper shredder has stopped working. There is nothing jamming it - what should I do?
I had this same problem on one machine i repaired and when I took off ththe top cover it had a bad gear where it was split and it would run fine backwards, but not forward. the gear is available online. it was also
clogged with paper, which must have caused a lot of torque on the gear. they are plastic, so they will break instead of really messing something up. good luck
Jul 24, 2012 | Fellowes P-48C Cross-Cut Paper Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
168 people viewed this question
jasbo
jasbo
