Question about Canon imageRUNNER 400S Copier
Gp 405 error e220 - Canon imageRUNNER 400S Copier
  • Lance Farrell May 11, 2010
    Do you even know what inappropriate means? E-220 does indeed relate to the exposure lamp. If that is not your problem then it ranks a "thanks for trying". There are other, non related faults that can cause this error, and one well known fault will have you chasing your tail for days if you dont know what it is.
    Generally, you get better responses if you at least attempt to show some effort on your part.  Give some detail such as: what have you tried so far? when did it start? are there any other symptoms?
E220 eroor
Posted on Dec 23, 2008
    Problem Solver:
  • 12 Answers
Look at exposure lamp and pre exposure
Posted on Nov 24, 2008
3 Suggested Answers
SOURCE: Cannon GP 405 error code E100, E301, E220
If you have error 301, 100 & 220, just open the cover of camera and clean the camera lens and just remove white strip of the board and clean and replace it, then its works successfully
Posted on Nov 23, 2011
SOURCE: CANON GP 405 ERROR E 051
hi
horizontal registration home problem sensor(ps14),motor,dc controller
Posted on May 04, 2009
Canon 405 error code e805
http://www.copytechnet.com/forums/canon/9744-canon-gp-405-error-e805.html
Quoting:
  1. Canon GP 405 error E805
    E805 (The fan rotation is faulty.)
    If no detail code is indicated,
    suspect the feeder fan (FM1) or the
    reversing guide cooling fan (FM9).
    Is the connection of these fans
    normal? Is the drive signal of the fan
    identified in the previous step about
    22 VDC while the fan is rotating orabout 12 VDC otherwise?
  2. 05-14-2008 #3 songela Senior Tech 100+ Posts
    Join Date Mar 2008 Location dar es salaam
    That is one side with the fans,
    Secondly, if the fans are found right, then for sure you need to change the DC Controller.
    Regards!
  3. 08-02-2013 #4 mehta Junior Member Re: Canon GP 405 error E805
    Originally Posted by logimix
    Could somebody tells me... what this error (E805 - Canon GP 405) is... and how to resolve it? thanks a lot. john pl check detail code after 805 .Fan related fault. Also power supply(composite)
Apr 29, 2018 | Canon Office Equipment & Supplies
Canon gp 335 erorr code e805 what is the problem
Canon GP 405 error E805 E805 (The fan rotation is faulty.)
suspect is feeder fan (FM1) or reversing guide cooling fan (FM9).
try Check
Mar 25, 2012 | Office Equipment & Supplies
GP 405 error e030
It could be that your copier's COUNTER have problem and need replacement before that, cleared the error fisrt in copier service mode.
Apr 22, 2011 | Canon imageRUNNER 400S Copier
Error code e220 for canon gp 405
That is a scan lamp error on all Canons that I know of. Check continuity on the lamp. Then check the in line fuse. It could also have a shorted scan cable.
Nov 09, 2009 | Canon GP-200 All-In-One Printer
My machine gave me an error E051 and it could not start. when i restarted, it still ended at that.
i decided to switch it off and wait for the technician to come and fix it.
the next morning i arrived before the technician came and when i switched on, it was very fine.
what could have happened.
Tonny Obwin Telecommunications engineer.
May 02, 2009 | Canon imageRUNNER 400S Copier
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
608 people viewed this question
old marine
old marine
