Question about GE JKP15 Electric Single Oven
Set, Start and Time Beeps
The Set, Start and Time lights come on by themselves, stay on for a short period and then turn themselves off. This happens continually every few minutes. The oven is not turned on. Please help.
    President:
  • 1,314 Answers
Im going to contack a friend of mine at ge technical about issues on this oven after holidays check back
Posted on Dec 29, 2007
Broiler comes on on top oven every time you turn bake on and won't go off. Recently replaced temp sensor for similar sporadic problem and worked for a while but now happens every time
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
May 20, 2015 | Ovens
How do I fix oven staying on
Oven Control Board
Relay board:
Apr 22, 2015 | Ovens
Fisher Paykel double oven light and heat won't shut off
Oven Control Board
Relay board:
Mar 13, 2015 | Fisher and Paykel Ovens
We have a whirlpool double oven, model RBD245PDB12. Oven cooks well but, will not stay off, buzzes long and short intermittently throughout day and night flashing F2 code or E6.
Oven Control Board
Relay board:
Feb 13, 2012 | Whirlpool Ovens
GE profile lower oven does not turn off...maintains low heat with the convection fan on for several hours.. When i turn oven back on and then off it stops...but the problem continues to happen periodically
Oven Control Board
Relay board:
Sep 12, 2009 | GE Ovens
I have an older Sears Kenmore oven. It has the
the internal fuse is blown out and the circuit breakers gone short its a reparing job not a resetting job.you will have to opoen the oven and get the circuit breaker checked and repaired or replaced.
Mar 02, 2009 | Kenmore Ovens
Oven does not start
This is an update from James758. When I pressed the temp sensor probe and wiggled it a bit, sometimes the oven would work, but then it failed permanently after a few days. Had to call a repairman who charged $325 to replace the entire electronic panel and the separate sensor, although the failed part was only a relay on the board according to him. He also found a pinched wire when he pulled the oven out (one new electronic board relay failed when he first replaced it). Don't know how the wire to the sensor got pinched since the oven worked for 8 years without us moving that hidden wire. By the way, buying the sensor at a parts store in town was $18 versus his cost to us of $49. I'm sure the electronic board would also be much cheaper online. My wife watched the repairman replace the parts; you can save a lot of money doing it yourself.
Nov 14, 2008 | GE Profile JTP18 Electric Single Oven
Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Nov 10, 2008 | Ovens
Oven turns on by itself
only thing i could say here is replace the control or clock its real name is an eoc electronic oven control now the part is under a five year warrenty but you have to pay labor and use some one that is authorized for ge warrenty work check your owners manuel for second to five year warrenty and go to ge web site to locate servicer in your area http://www.geappliances.com/service_and_support/service/
Jun 04, 2008 | GE JKP20 Electric Single Oven
Whirlpool GBD307PDS Double oven stopped working.
The beeping sound is a fault code. Problem is it isn't listed. In either the top or bottom oven panel there should be a service sheet. The codes are located on this service sheet.
Jan 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
GE JKP15 Electric Single Oven Logo
76 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
