Question about Photography
Re: Shutter button working very intermittently
My camera is a (very old - 1995) Olympus Superzoom 120 35mm) and the shutter button isn't working properly. My question is really, is it worth trying to get it mended? There is rubber poking up round the shutter button & it is possible to pull out the top which is attached to a "concertina" of rubber underneath. Looks a bit serious to me? Would I be better off buying a new camera??
  • foxhazel Nov 24, 2008
    Thank you! This is really what I suspected - this camera has been brilliant up to now, but given its age & the advance in technology I think it would be more cost-effective to get another camera, most likely digital (I was just waiting for an excuse to buy one!)
  • 667 Answers
Probably, finding the right part to replace the button may be difficult. Even if you could find the part, labor would make the repair not cost effective.
Posted on Nov 24, 2008
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
Shutter release inoperative
The "button" is actually just a plastic extension for the actual switch on the printed circuit board. You will have to dismantle the camera to gain access to the board and then use a DMM to test the switch contacts.
Oct 04, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Olympus C-8080, everything works except the shutter release. I press the shutter button, auto focus is done but "no shutter release". Any ideas? Derek
Does the shutter button feel like it's contacting twice as you press it in? if not, the spring disk in the switch is split; It has happened to me on other cameras on several occasions. Solution is to replace the switch.
If it works otherwise I would suspect the ribbon cable. They can get loose, or the contacts can get oxidized. I don't know specifically about the c-8080, on some cameras the contacts are tinned, which can oxidize. In that case it's a matter of gently rubbing the contact strip with a paper eraser until the contacts become shiny. Of course, that means disassembling the camera ;)
You've probably retired this camera or don't have it anymore but in case you still have it, I hope this helps a bit.
Apr 28, 2010 | Olympus Camedia C-8080 Wide Zoom Digital...
How do you put the film in in a olympus superzoom 105g
Open the back, gently blow out any dust that might have gotten in there. Load film in the shade. Take the film cassette out of the plastic container and insert it with the protruding piece on the bottom into the left side of the film compartment. Gently pull the film out to the right about 3-4 inches. Try to keep the film flat across the shutter opening but Be Careful you don't touch the Shutter Blades! Feed the film under the take-up spindle and through the vertical slot and hook the film into a sprocket. Push down the shutter release button and advance the film a couple times. Close the camera back securely. You are ready to go! Good luck
Aug 03, 2009 | Photography
Olympus e510 shutter button locking up
reset the camera through the menu.... put the camera in P mode, menu, right over to card setup, down to custom reset, right arrow, ok, up arrow to yes, ok
Oct 14, 2008 | Olympus EVOLT E-500 Digital Camera
Dropped the camera and now...
Sounds like the chassis under the shutter button has somehow distanced itself from the shutter release button, maybe bent away from the button? Its s stretch but that maybe the problem. The button is designed to have 2 contacts in it, the autofocus switch and the shutter release depending on how much you press it, like most cameras
Nov 09, 2007 | Olympus SP-500 UZ Digital Camera
My camera will turn on but the shutter won't open!
tiny bits of juice, remember? maybe (or I am sure) this tiny became corrosive inside the camera. (orange juice is the no.1 in my corrosive juice list, water is the least). You need to open and clean it, or a pro fix is necessary.
Sep 09, 2007 | Olympus FE-190 Digital Camera
Olympus C-750 shutter problems
Changing the firmware won't change anything. The micro switch may be stuck in the on postition. If you are familiar with micro circuits, you could get the switch from Olympus or and replace it. Or, send the camera to Olympus or an Olympus authorized shop.
Apr 16, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Olympus 300 mju
well sometimes that happen, and can be two things 1st the camera got very wet, or the button inside got broken and needs to be replaced.
Feb 09, 2007 | Olympus MJU 300 Digital Camera
Photography Logo
121 people viewed this question
Top Photography Experts
Are you a Photography Expert? Answer questions, earn points and help others
