Keygen not fully visable
I have a keygen for a screen saver program however the bottom part of the keygen isent there so i carnt press generate ! this keygen does work fine on other computers running the same os as mine xp my question is what could be coursing the the bottom part of the keygen not to show and how can i fix it . hope you can help thanks .
  • nightligh452 Dec 02, 2008
    sorry i havent given a rating but im having trouble with the VB2008 express edition it encounters a problem during setup and shuts down ?? ive run the nod32 and the outpost and the anti- malware and the reg-medic and the systems clean so onece i can get the vb to run ill then be able to post a rating , thanks
  • nightligh452 Dec 10, 2008
    i managed to fix the problem :) the DPI setting was set ay 120 so i reset it to 96 and woe & behold everything could be seen . thanks all the same white russian .
    An expert whose answer gotĀ voted for 100 times.
  • 167 Answers
Most "keygens" are written in either Visual Basic or Visual C++ and about 90% of them are packed with a Trojan.
If you install the Visual Basic 2008 Express Edition it updates and fixes any ActiveX / COM components in the system registry that is need to run VB apps; you don't have to keep it installed.
I would also consider running a registry repair tool like Uniblue Registry Booster to fix any existing damage to the system registry. After a registry scan, redistributable for VB and C++ are installed you shouldn't have anymore problems running that keygen; unless there is a trojan packaged with it.
Keep virus protected on your system if you are going to continue running keygen apps.
Posted on Nov 28, 2008
  • Dominic
    Dominic Dec 04, 2008
    A good virus protection application will not let Trojan's install into the system; some rare cases the application hangs.
    My McAfee Security Center would automatically delete the program when I browsed the directory; doesn't even prompt me to make a discussion how to proceed. So, I'd never get the chance to run if it was a black app...
    More food for thought:
    If the application was compiled on a 16-bit/32-bit DOS system like Windows 95, and you're trying to run it on a 32-bit/64-bit NTFS system like Windows XP you will have compatibility issues.
    Steps to resolve:
    • Right-click on the application
    • Select "Created Shortcut"
    • Right-click the shortcut
    • Select "Properties"
    • Select the "Compatibility" tab
    • Under "Compatibility Mode" put a check in the box
    • Set the compatibility mode for "Windows 95" and "Apply"
    • Run the shortcut for the application
    (This is just emulation and is not 100% but resolves most compatibility issues; it will not let the application overwrite a file that is flagged as read only, protected system, etc. )
    Furthermore, if the program is clean and Trojan free, and you're sure there is nothing wrong with your system, then it could be missing a required resource or be a corrupted file. You can attempt to run it on another computer to see if it runs...
How to turn off screen saver on an Acer Aspire v5
right click your desk top and select personalize
on the appearance and personalization page
at the bottom right corner is the screen saver click on it
screen saver drop down menu change it to none and press ok
Jun 03, 2014 | Computers & Internet
How to get ADOBE PHOTSHOP Authorization code..
Hi to all<br /><br />I have the link of FULL ADOBE PHOTOSHOP CS3 with authorization code<br /><br />you need to download all the links from part 1 to 6...or you may choose which mirror you want to download.<br /><br />the keygen is located at the bottom ..<br /><br /><br />here are the steps on how to use it..<br /><br />1. Use the keygen to generate a serial number<br />2. Copy paste it into the Ps CS3<br />3. Click next<br />4. chose to activate by phone<br />5. Run the Authorization Generator<br />6. copy the activation key ( it will be under the serial number in Ps CS3 ) into Authorization Generator ( in the activation Number section )<br />7. Press Authorization Code to get the Authorization Number<br />8. Copy the Authorization Number into the Ps CS3<br />9. U will fined that the last Four Numbers in the Authorization Number is always (5727) Change it To (6495)<br /><br /><br />here's the link:<br /><br /><a href=""></a>
on Feb 08, 2011 | Adobe Computers & Internet
Plugs 1 & 2 become sooty,while plugs 3&4 burn a nice tan coulour 2007 nissan 1400 bakkie 52000 kms on the clock
Hi there. Well at 52k it carnt be to bad so remove the plugs from 3,4 and fit to1.2 and start and run ,if they also turn black and sooty then it isent plugs .but if they stay ok then replace plugs in 3,4.
Other wise its either valve guides on 1,2 or piston rings letting oil pass the oil scraper ring .
But at that milage it carnt be much.
Aug 10, 2011 | Datsun Pulsar Cars & Trucks
I bought a latest 11 inch VAIO Y SERIES. It has windows 7. Im unable to change the screen saver. please guide me
To change the screen saver right click the desktop and press personalize. In the bottom right corner there is a setting for screen saver where you may select a new screen saver.
Apr 22, 2011 | Computers & Internet
How can i activate my cs3 design premium when i cannot open the keygen.exe file to get the activation code thank you
You can't open your "keygen", to crack or hack using a generated code for the software you have installed? If any security programs is installed on your PC ie. antivirus, or internet security. they might block or quarantine the program from starting. (Most security programs consider "Keygen, patches or crack files" malicious in nature because they changes the system Registry". Another thing is that the "keygen" is corrupted or the "keygen" is built using the .netframework platform so you have to install the necessary .netframework in order to get the "keygen" working.
If you are not sure about using any "cracks" best is not to use them because those "cracks" might screwed up your PC.
Hope it helps.
Aug 26, 2010 | Adobe Computers & Internet
My proview 558 monitor has a 1/2 inch black line at the bottom
ms_biguns, You need to test one or the other, The tower should output and drive a substitute known good monitor, or a known good pc should be able to display the WIN-desktop screen on your Proview 558. Could it also be that the software in pc not set up for driving a Proview558? 12fixlouie
Feb 28, 2010 | Proview Computers & Internet
How get a authorization code of my adobe photoshop cs2 plss let me know me
this is how you get authorization code:
  1. Go to google or youtube and search for: photoshop cs2 paradox keygen
  2. If you find it open it and then open Adobe photoshop cs2
  3. press generate serial and type the serial you get in photoshop and then ok
  4. They will tell you that the serial is invalid then you have to press purchase by phone
  5. Once you press that you will find an activation key copy it and paste it in the paradox keygen then press generate auth code it will display it in the last box in the keygen.
Good luck
Jan 18, 2009 | Adobe Photoshop CS for PC
you will find an .exe file provided along with the file you downloaded it..
just paste the avitation code in it and click on generate. it will generate a new key.
use that and enjoy installation
Jan 03, 2008 | Microsoft Windows XP Professional for PC
Keygen &ragistration code
I am sorry but keygens and code generators are illegal and this site is not the proper forum for looking for such things. However a good program for sharing of information is limewire
Oct 23, 2007 | Best Software ACT for Palm OS - Instantly...
Computers & Internet Logo
536 people viewed this question
David Payne
David Payne
