Question about LaCie Electron III 22" CRT Monitor
Monitor goes to standby mode intermittent.
I have lacie 22 blue III 22" CRT it keeps turning off by itself intermittent, power LED goes amber and flash i have to turn it off and back on again. Could someone help please.
  • tyho Feb 12, 2008
    My computer was in sleep mode. I came home, and the light was flashing. I tried turning it on and off. I tried, moving cable from slot on to slot two. Nothing, the screen is just blank. I am currently working on a piece of crap monitor, that always works.
  • 9,156 Answers
Sounds like this one needs component-level troubleshooting in the power supply section.
Posted on Jan 02, 2007
2 Suggested Answers
SOURCE:
burns-o
  • 114 Answers
SOURCE: Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Posted on Jun 12, 2008
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
I have a LiCie electron Blue crt monitor. I have
You have a bad connection or break in the wiring. Fix that and your monitor will work properly. Could be the wire itself or the plug you use to plug into.
Mar 05, 2017 | LaCie Electron III 22" CRT Monitor
The monitor doesn't go on. the orange standby light blinks on and off. is there a reset?
Sounds like the issue is with your video card/onboard video chip or the connection between the monitor and the pc. Verify the cable from the monitor is connected to the pc firmly & snugly. See if the monitor gets a picture on a known working pc. If so, then it's a (relatively) simple fix - work on the videocard - if add-in, try reloading drivers, ensure the onboard video is disabled in the BIOS, or (worst case) replace the video card. If it's onboard, again, try replacing/updating drivers and, if that fails your next step is to either get an add-in video card, or replace the mobo.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/chris_796687fbded27b53
Aug 13, 2009 | LaCie Electron III 22" CRT Monitor
Display went off after a sound like a cracker
sounds like a capasitor poped on the power board if the case you will need a new display the board is more expinsive sorry
Jun 29, 2009 | LaCie Electron III 22" CRT Monitor
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Cables
Justa VGA monitor cable and a USB for th hub
Aug 25, 2008 | LaCie Electron III 22" CRT Monitor
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Monitor powers down upin startup
you need a new video card. it is powering down becuase it is not reciving any signal from you computer. if you are useing onboard video (vga) get a pci video card if you are useing a pci card try puting it in a dfrent slot.
Dec 20, 2007 | Gateway 310S (2900621) PC Desktop
CRT discoloured
If it's a deguass problem, you can glue some very small magnets to the sides of the crt tube itself, it could be the shadow mask, inside the monitor, and if it is then nothing will fix it, if you can get a deguass coil from somewhere that would tell the story real quickly
Nov 04, 2006 | LaCie Electron 22blue II 22" CRT Monitor
LaCie Electron III 22" CRT Monitor Logo
262 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
