Question about MSI RG54G2 Router (MS-6848-002)
File sharing on WLAN by MSI RG54G2
I have MSI RG54G2 as an AP servicing sevaral clients (PCs, PDA, DVB..). Each of the devices (with a fixed IP) can access the internet services, but cannot see and communicate to each other. I can see they are commuinicating to MSI RG54G2 (via association client list) but they cannot be pinged neither from the other client nor from the MSI RG54G2 directly. How can i fixed that?
  • kniz_peter Dec 02, 2008
    Thanks, but that did not help. The devices "dont see" each other first. If this is not the case, then i can start allowing the services...
  • 57 Answers
Is "File & Printing Sharing" are already added in each LAN properties? if not try to add and restart your computer.
Posted on Nov 27, 2008
This AP is in network x.x.102.0, which has it's own DHCP server. Only lan-port and WLAN are used on AP. I need this AP not to have it's own ip-adress, but devices, that connect to it,using WLAN,...
Ideally, there shouldn't be any configuration needed. Access points are transparent and only work as a bridge between wireless and wired network so devices should obtain their IP info from your DHCP server not the access point by default.
If you face problems, then there might be a DHCP server in the access point, disable that.
good luck
May 20, 2011 | Symbol AP-5131
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
How to setup internet between 2 EnGenius EOC-2610 devices?
Thanks for a very thorough problem report. It's a little ambiguous near the end, though, so I will have to restate what I think I understand you are saying.
You are saying that you have your internet connection and AP in one building, and two devices or PCs in that building can access the internet and share files (though you don't specify if they are using the EOC-2610 access point or are just accessing the router in some other fashion). But you have a remote building where there is one PC and one EOC-2610 in Client Bridge mode, and although both EOC-2610 units seem to be communicating with each other, the PC will not communicate with anything. (I presume you have inspected the access point's configuration screens and verified that it does have the other EOC-2610 listed as a connected client.)
First, the PC in the remote building has to be connected to the Client Bridge EOC-2610 by its ethernet cable in order to access the network. Second, the PC in the remote building has to have a valid IP address in the range, or it won't communicate with anything. If you are relying on your router's DHCP to assign your PC an IP address, verify that this has happened by examining your PC network properties. If you are assigning all IP addresses manually, make sure you have assigned the PC an address, and one that doesn't duplicate some other device.
Sometimes failure to specify DNS servers appears to be a lack of communication with the network. Open a browser and type in the URL bar. If you get to, you have a good network connection. If you type in the URL bar and can't get the same result, you need to define DNS servers on the PC (or inside your router).
Mar 13, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
I have a iphone 3gs and want to access wifi or wireless on toshiba satellite pro x200
Laptop normally have single chip WiFi or Wireless Cards...
These cards could be used as client(connecting to wireless router), adhoc or access point(a WiFi card could be used as Access Point to route your LAN(Wired) connection on WLAN)...
Your laptop WiFi card is already busy as a Cleint, so if you want to use it as AdHoc, you have to remove all the other connection with the, Disconnect the WLAN from connecting other devices, and follow the below mentioed steps to connect your device..
When you are using Client mode you are not able to use it on Ad-hoc or Access Point feature...
Setup laptop to Ad-Hoc
1)Navigate to control panel and choose network connection, Right click on the Wireless network connection and click on the Properties on Wireless NIC
2) Click-Wireless Networks Tab
3) Click-Add
4) Provide SSID Name, name to identify you rnetwork
5)Security -Net Auth: Open
6)Make -Data Encryption: Disabled
7) In the check box present-Check on This is a Computer to Computer (ad-hoc) network.
Change the IP address of the Wireless NIC card, by choosing TCp IP in the properties of WLAN and choosing TCP/IP v4 from the installed service
TCP/IP on Laptop
TCP/IP on iPhone
-Static IP
Now try searching for Wireless through your phone, you should able to connect..
Please leave me comment, if you need further assistance
Nov 01, 2009 | Computers & Internet
Connect MSI RG54G2 to speadstream 4200
so that means if you connect the computer to the modem, it works but not with the router.
it seems that the router and the modem are not communicating with each other.
When you connect the computer to the modem , check the IP address through the modem. If ti is private IP address then you will need to change the settigns on the router.
Click Here for more info about networking
Oct 14, 2009 | MSI RG54G2 Router (MS-6848-002)
The Pre-shared key is used to setup encryption on wireless routers.
The latest strongest encryption methods used is Wi-Fi Protected Access (WPA and WPA2).
The wireless router is configured with WAP or WAP2, and the computer's wireless card is configured with the router's WAP or WAP2 encryption. The wireless router will now allow communication with the computer's wireless card, data transmitted between the router and computer is encrypted and therefore protected from unauthorized access.
Sep 08, 2009 | MSI Wireless-G RG54G3 Router
Ipod touch - wireless connect to my MSI RG54g2 router
Hi and welcome to FixYa,
Initially, to your queries:
  • instruction book - pls click here;
  • passwords - open a browser, the MSI RG54G2 web interface is, password is "admin", less the quotes;
  • iPod touch - will auto detect your MSI
  • setting on my router - if allows your computer(s) to access the Internet, no further settings required;
  • iPod can connect to the internet - if no WEP or WPA is set on the MSI router.
This is of course assuming that the MSI RG54G2 is allowing your computers to access the Internet lready and will be shared to the iPod Touch.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 25, 2008 | MSI RG54G2 Router (MS-6848-002)
Dial up?
Technically no, not unless the PC where the modem is connected to is used as a Gateway/Share Internet Connection and is connected to the WAN side of the router. However, this arrangement would need a lot of manual configuration and settings on the modem side PC as well as the client PCs.
Alternately, you may be better off connecting the modem PC to a hub rather than a router and set static IP adds on the client PCs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jun 24, 2008 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
Lost contact between PCs connected via AP
Set all the PC's to have a manual IP rather then using the DHCP from the router.
Also set the Gateway and Preferred DNS on the network cards to the routers IP (IE
Apr 18, 2008 | Edimax EW-7206APg (EW7206APG) 802.11b/g...
Access remote system devices
if need to access the device of your client,just follow the steps.
we take cd rom for eg to access.
1.right click the drive there you see "sharing and security" on the and enable share as cd rom.and give maximum allowed.
3.then from your system.Run->ip of the machine->enter. shows all the share file of the client machine
if want access remote desktop
1.enable the remote desktop connection in the remote machine RUN type MSTSC the remote desktop connection will popup.
3the type the ip of the client machine
Mar 20, 2008 | Computers & Internet
MSI RG54G2 Router (MS-6848-002) Logo
124 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
