Question about Linksys Wireless-G WRT54GS Router (e125894)
Prohibit intruders i would like to know how to prohibit others from accessing my wireless. I would like only one more computer to acces wifi.
Yeah, thats the most simple solution or that. also you could enable your wireless router to use WEP key that only you knows, in that way no one could access your wireless network witout knowing the key
Posted on May 11, 2007
  • 624 Answers
I have several of these and the easiest and most effective way is to use the MAC address filter. Your manual should explain exactly how to do this but if you have any questions let us know.
Posted on Dec 31, 2006
Cisco Acces Point series 1020 Air-AP-1020-A-KG
This is an enterprise AP and needs to run with a Cisco router.
Mar 30, 2014 | Cisco Computers & Internet
Can not acces my own home wifi, want to reset D-link and make a new access code
Reset the router and then configure it again.
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to 3.05) Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (WPA or WPA2 encryption) Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Nov 04, 2012 | D-Link DIR-625 (790069292637) Wireless...
I have acer laptop 5580. 3 year old. Recently i have installed Windows 7. Wireless was working nice. Now, system is identifying the wireless, but not connecting. After troubleshooting it is giving...
If your device can detect other acces point then, your wifi device is correctly installed. If not, os will tell your wifi have problem. If you try connect, and have problem with connection, it came from your acces point(wifi router expample). Maybe it have password that have not match with your pc. If that access point is yours, then you can try check the password for wifi using cable connection.
If that acces point(wifi router) is not yours(public), then you cant get the password unless you try hack using air-ng, backtrend using wifi device that can capture and monitor the network(wifi *** support a/b/g exmple) if it only support b/g, you cant get wep encryption password.
If it does not have password, and you try to connect, but it still problem, that mean, it have restrictly to MAC address in wifi router.
May 09, 2011 | Acer (BCM94318MPG) Wireless Adapter
My neighbors are able to use my router how do i install a block/password
Hi d_smonty! Here is the minimum recommendations I provide for anyone that set up a home wireless network for.
1. Change the default SSID for the access point. To many folks know the defaults
2. Change the default ADMIN password. Again to many people know the defaults.
3. Turn off the broadcast of the SSID. This will prohibit other folks from knowing you have the wireless access point.
4. Turn on MAC filtering. While it is true that many newer network cards can be set for MAC filtering without knowing the proper MAC they still won't get in.
These 4 steps will set you up for basic Wireless security and can be done on your own. Make sure you are doing this from a computer that is wired to the access point. Otherwise you will lose your wireless connection ad not be able to get in and change things. I also recommend that after each step you check the wireless connectivity.
Finally if you access point/router is providing Dynamic IP addresses to the other computes you can change the range of those IP addresses to be different then the default setting. Please feel free to contact me here under your topic if further assistance is needed Regards
Feb 28, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I have a new laptop computer and am wondering how I log on to internet as it is asking for my access/security code?
I assume you are connecting thru wireless or wifi. If its asking for the security code then you have to know the security password for the SSID on that wifi router. Many Wifi routers have security passwords before you can access the internet. If you are connecting to your wireless router then just disbale the security password but will be disadvantageous because other people can connect to your router. Just ask the person for the password who initially setup your wireless router.
Nov 05, 2010 | AMD Sempron 2800, 2.0 GHz 2800+...
How do you set up WAP or other encryption
You can secure your Wireless Network from your ZyAIR Acces Point.
Login to the Access Point as follows (make sure that it is connected to the Computer):
1. Start the Web Browser like Internet Explorer or Firefor or Safari.
2. Type 192.168.1.2 as the URL.
3. Type "1234" (default) as Password.
4. Go to the Wireless LAN Setup option.
5. Set the Wireless Network Password (either WEP or WPA type).
Done.
You may also refer the User Guide of the ZyAIR Acces Point page # from 40 to 60 for more information about this.
Good Luck!!!!!!!!!!!
Nov 11, 2009 | Zyxel ZyAIR B-3000 802.11b (ZAB3000)...
Just bought a I9 3G phone,but doesn't have a wifi device.It is there a way I can get internet acces,any application or something. Thanks V
Sir,
Well you can use GPRS to it, but if you have Broadband DSl, then you may buy a device know as Tp link or D link with wireless router it would make you connection wireless and you can also use wifi on your 3G cell phone.
Aug 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Need to know how to reset password so neighbors can"t access my internet
http://192.168.15.1
this is defaults link for acces belkin router
then go to wi fi security then u see encrption security then u can reset pasword easily.
May 07, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wifi
WiFi is not based on your computer, it is based on what you have connected to your internet modem. If you want WiFi then you will need a router that provides WiFi transmission. These routers also have standard ports to connect your equipment that doesn't support WiFi. Most Laptop computers sold now a days have wireless modems intergrated so if you upgrade your router you dont have to worry about having to buy a bunch of other things.
Jan 06, 2009 | Apple iPhone Smartphone
Where enable wi-fi acces on Averatec 6100 series?
right nest to the power button is the wifi antenna button insure that it is green indicating that it is turned on
Dec 20, 2008 | Averatec 6100 Notebook
Linksys Wireless-G WRT54GS Router (e125894) Logo
22 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
