Question about Whirlpool LSQ8000 Top Load Washer
Does not agitate or spin - Whirlpool LSQ8000 Top Load Washer
    President:
  • Whirlpool Master
  • 2,651 Answers
Listen for a "clicking" noise when opening nad closing the lid, sounds as if the lid switch migh tnot be making contact, but if it is running, just not agitaing or spinnning, you may have a problem with the motor coupling, this machines equivelent of a belt
Posted on Nov 24, 2008
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
I have a Kenmore washer model 110.26832690 that will not spin. It will fill up, agitate, but on spin cycle it will only drain. Does this sound like a bad lid switch or a bad drive adapter? From what I've...
if it agitates correctly,then its likely your lid safety switch, agitate and spin cycles are reversed by the motor during the cycles of agitate and spin,some units are wired to not operate on either agitate or spin,but some will operate on agitate with the lid open,but not on spin,open control panel and bypass the lid switch and this will tell you before you tear out the direct drive pump,motor and get to the d.d. coupler at the transmission
Mar 20, 2011 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator doesn't agitate. Fills, spins and drains
Unfortunately, that sounds like a transmission issue. Power is getting to the trans, or it wouldn't spin, but the other part of the trans that causes agitation is broken.
Nov 15, 2009 | Washing Machines
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Agitator free spins
Remove the top cap on the agitator and see if the bolt has come loose. If it is not there, the agitator will come loose from the gear case shaft and free spin.
Mar 21, 2009 | Frigidaire FWS833A Top Load Washer
Spin cycle with agitation motion occurring simultaneously
Hi again,
Appreciate the "Ask Me".
I believe the dampness is due to slow spin speed as you also have concluded. And I suspect that partial winding of the motor is the culprit. Hence, replacement is in order.
As to your concern why the agitator also operate during the spin setting, it could possibly be stuck or locked agitator dogs. Agitator dogs function is better explained here by another FixYa member, jsrock516.
Cheers.
Jul 25, 2008 | Washing Machines
Whirlpool LSQ8000 Top Load Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
prem mathew
