Question about Epson Stylus CX4600 All-In-One InkJet Printer
Cx4600 scanner will not work
My scanner used to work with my desktop PC. I have gone through the troubleshooting several times. I have uninstalled the software and reinstalled, still same problem. It displays "unable to access the scanner because it is not ready or another app is using it. I have tried connecting to different usb ports. I have never used any other App to scan with. I have the cx4600 software installed on my laptop and using the same printer usb cable from the printer it works fine. So I Know it is not my usb cable. Any suggestions.??
  • Anonymous Aug 25, 2008
    i lost my software, and iam trying to install the epson from the model number, which im hoping this will work.
If you've had a windows update this may be the problem. try downloading and installing any newer version of the Cx4600 drivers
Posted on Aug 06, 2007
SOURCE:
I plugged it in and all of the lights come on, but when I press scan, nothing feeds. I hear no mechanical noise like it is trying.
Troubleshooting Scanner Problems in NeatWorks for Windows
www.neat.com/.../troubleshooting-scanner-problems-in-neatworks/
Troubleshooting Scanner Problems in NeatWorks for Windows ... Plug the scannerback into the computer, start NeatWorks, and try scanning again.
NeatConnect Scanning Issues - The Neat Company
www.neat.com/helpcenter/neatconnect-scanning-issues/
My LED screen wont turn on? If this is the first time using the NeatConnect scannerand you are not using it with a computer, please confirm that the cord is ...
Download Neat Software' Activate Neat ' Neat Company
www.neat.com/helpcenter/download-neat-software/
If you are looking to download or activate Neat software for your scanner, visitneat.com/activatend for more information. ... Desktop Software (For Existing Users) ...
Support - The Neat Company
www.neat.com/support/
Neat's Smart Organization System desktop software. ... Fast and efficient scanners to help convert your paper mess into an organized digital filing system.
Jan 14, 2016 | NEAT Desk Desktop Scanner and Digital...
Canon FB630u problem
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolution
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Try these options:
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard. Click Uninstall, and then click Scan for hardware changes to load a usable driver. Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true)The registry information applies to Windows XP.
Mar 01, 2008 | Canon CanoScan FB630U Flatbed Scanner
As I want to scan a paper, scanner does not work properly. I tried many times but the scanner cut the paper from diffent areas as I tried over and over for several times. I got the exact scan maybe ten...
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
May 02, 2011 | Computers & Internet
How do i get my mustek 1200 iii ep flatbed scanner to work with windows xp. my computer restarts every time i clink on scan.
If you have the orginal software that came with your scaner and it says that it is compatible to Windows XP, you may need to use the disc to reinstall it. YOu will first need to turn off the scanner and unplug it from the PC. Then uninstall the old software from install/uninstall in your control panel. (start>control panel>install/uninstall programs, search the list for your scanner software.)
If you do not have the software or it is not for Windows XP:
There is the link to a site with a driver download specifically for your scanner, instructions on installing it for windows XP and also a link to answers to problems for your specific scanner.
http://www.mustek.com.tw/Download/driv_scanr/english/1200ub.html
Before you begin any download make sure your virus control software is up to date.
First click on the link "Instructions for XP installation and print it out.
Next click on a driver for XP from the chart to download it. When a window pops up click save and browse until you locate desktop. Save this file to your desktop. It will be an .exe file.
Turn off your scanner and unplug it from your PC and uninstall the oldsoftware as advised above.
Click on your new driver file to install it. Follow instructions.
Once the driver is installed, plug the scanner back into the computer and turn it on.
Restart your computer.
It should now recognize your scanner.
Try a scan.
Dec 18, 2010 | Mustek Plug-n-Scan 1200 III EP Flatbed...
Desktop icons are gone inc time sound and start icons
Hi There,
A few options you could try here,
i. Uninstall any programs you installed just before having this issue..
2. Restore you pc back to the time/date when all was working well.
Hope this helps...
Dec 11, 2009 | Computers & Internet
Scanner not scanning
Helen, I feel that the scanner part of the SW has gone corrupt for whatever reason. You must first uninstall the scanner from Control Panel. The reboot the PC and reinstall the scanner. Once done then only you must connect the scanner to the PC. Now allow some time for the Windows to detect the scanner and load its drivers. And when you get a message in the right bottom corner of the screen saying "Your new HW has been installed and is ready for use", you can start scanning documents either from specific program for it or from the word processor. Hope it works for you.
Dec 04, 2009 | HP Office Equipment & Supplies
Canon mp 240
YOU CAN TRY CLOSING EVERYTHING OUT BEFORE USING THE SCANNER
IF THAT DOES'NT WORK SOMETIMES UNINSTALLING THE CANNER THEN REINSTALLING WILL FIX THE PROBLEM
OTHERWISE YOU MAY NEED TO UPGRADE YOUR MEMORY
Jan 13, 2009 | Dell Dimension 3000 PC Desktop
Sony vaio VGN-TX27GP
you probably need the drivers hp scanner for vista if that is your operating system let me know make and model of scanner will find them for you
Jul 31, 2008 | Sony VAIO VGP-BMS33/B
Unable to scan, Unable to get the scanner to even be found (but twice)
Do you have a spare USB cable. Sometimes if that goes bad, that happens.
Try another available UBS port as well.
Jun 16, 2008 | Microtek ScanMaker 4900 Flatbed Scanner
Problem with Scanner
I am not sure if you have tryed this or if it will work yet I had this problem and did the following: Went to: Cannon Utilities MP Navigator 2.0 or other version Preferences Select Cannon Product using
Jan 18, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
