Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
RAM cuantity which ram cuantity is suit to the motherboard INTEL DISKTOP BOARD D845EPI/D845GVSR BQSR40202162 AA C45441-203
    Sergeant:
  • 177 Answers
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Posted on Nov 24, 2008
    Scholar:
  • 81 Answers
this info is from Intel.com
please read it carefully.
System Memory Features
The Desktop Board D845GVSR has two DIMM sockets and supports the following memory features:
  • 2.5 V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered single-sided or double-sided DIMMs
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • DDR333/266/200 MHz SDRAM DIMMs only
  • Serial Presence Detect (SPD)
  • Suspend to RAM
CAUTION:
Do not use ECC DIMMs with this board. Using ECC DIMMs could damage the board.
Integrator's Notes:
  • Registered DIMMs are not supported.
  • Double-sided x16 DIMMs are not supported.
Note:
To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
Supported system bus frequency and memory speed combinations
If the processor's system bus frequency is. . . You can use this type of DIMM. . . 533 MHz DDR333 or DDR266 400 MHz DDR266 or DDR200
Supported DIMM configurations
DIMM Capacity Configuration(Note) DDR SDRAM Density DDR SDRAM Organization Front-side/Back-side Number of DDR SDRAM Devices 64 MB SS 64 Mbit 8 M x 8/empty 8 64 MB SS 128 Mbit 8 M x 16/empty 4 128 MB DS 64 Mbit 8 M x 8/8 M x 8 16 128 MB SS 128 Mbit 16 M x 8/empty 8 128 MB SS 256 Mbit 16 M x 16/empty 4 256 MB DS 128 Mbit 16 M x 8/16 M x 8 16 256 MB SS 256 Mbit 32 M x 8/empty 8 256 MB SS 512 Mbit 32 M x 16/empty 4 512 MB DS 256 Mbit 32 M x 8/32 M x 8 16 512 MB SS 512 Mbit 64 M x 8/empty 8 1024 MB DS 512 Mbit 64 M x 8/64 M x 8 16Note:
In this column, “DS“ refers to double-sided memory modules (containing DDR SDRAM devices on both sides) and “SS“ refers to single-sided memory modules (containing DDR SDRAM devices on only one side).
Hello sir I am santosh from india; my intel desktop board serial D845EPI / D845GVSR , problem 4 beep and turn off pc
Did you check the RAM ?? . Remove Ram and Clean it and Put it back . and try . ( also remove Grapics card or any add on card if you have . Also try by removing HDD / CDD / DVD /FDD ect from the mother board and Just connect the Keyboard abd boot the Mother board . If your K/B Number lock can be toggled , then there is no problem in MB)
Please Rate My answer well and Support me !!!
Nov 23, 2010 | Intel Motherboard
The video driver for this board will not load. It
Minimum requirements also include RAM,Power supply,FSB,Processor speed...etc.Intel homesite "should" tell if it's compatible and with what.
Mar 24, 2010 | Intel Desktop Board D845EPI Motherboard
How much RAM is supported/expandable by intel D845GVSR motherboard
This board supports 333,266 and 200MHz DDR SDRAM up to 2 GIG.
Good Luck.
Nov 23, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Supporting ram for d845epi/d845gvsr
This link will provide you a list of ram modules compatible with that board. You should be able to reference the part number on your existing stick to check whether it's fully compatible.
Note: I am not affiliated with the linked vendor in any way, it is for illustrative purposes only.
Feb 26, 2009 | Intel Desktop Board D845EPI Motherboard
Regarding upgrading RAM
You'll need 184-pin ddr sdram memory
Supported speeds are 333, 266, and 200 mhz
Max memory for your motherboard is 2 gb, so the best you can get for your motherboard is:
2 x 1GB 333mhz 184-pin DDR SDRAM
May 21, 2008 | Intel D845GVSR Motherboard
Regarding Upgradation of Rams in My mother board
Please don't post your question twice, I've already answered your other post of this problem
Want to improve mt RAm size
Hi sanbme, you're Intel board can run 2x1GB of PC2700 / DDR333MHz Double sided memory. Two 2.5 V 184-pin DDR DIMM sockets with gold-plated contacts.
Serial Presence Detect (SPD). You can see Intel's web site breakdown of supported memory by clicking on this link.
http://support.intel.com/support/motherboards/desktop/d845epi/sb/cs-017166.htm
Scroll down to, "The following table lists the supported DDR DIMM configurations". Here you'll see the chart.
This next link supports the Intel D845GVSR motherboard for memory.
http://www.1stchoicememory.com/catalog/configurator.asp?b=INTEL&m=1955&p=C019551757
You can also got to this link & Crucial will scan you're system & make suggestions. http://www.crucial.com/store/drammemory.aspx
Enjoy!
Still have questions? Feel free to ask.
Mike
May 14, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
No display & beeps when power on
dharmesh,
it is ur video card..thats the problem..try to clean up ur video card..
Apr 22, 2008 | Intel D845GVSR Motherboard
Intel D845EPI/D845GVSR MB problem
if you can get past the POST properly and see the drive size, nothing is wrong with the drive hardware. I think XP is seeing a previous boot sector install so try first to fdisk, format and system boot the drive. This should remove any boot sector "shadows".
Dec 26, 2007 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
347 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
