Siemens 24 in. SE25T250 Free-Standing Dishwasher
Problem for Siemens 24 in. SE25T250 Free-Standing Dishwasher
Bottom rotating arm doesnt spray water but top arm does
By stephenprest on Nov 24, 2008
Symptoms are dishes on top trya get washed but dishes on bottom tray dont and rotating arm is still thru wash and rinse cycle.
Does anyone know if the Siemens dishwasher has two separate pumps (1 for top rotating arm and another for bottom)? I would suspect no, and therefore blockage in bottom feed. From a common sense view I cant see why there would be two separate pumps?
I tried looking for an approved engineer but nothing!
Solution #1
posted on Aug 07, 2009
Not Rated)
easkay
Rank: Apprentice
Rating: 0%, 0 votes
i have a similar problem. water is not reaching the bottom spray arm. there. i have an underwater case for my digital camera, so i'm going to put a torch or 2 in some waterproof bags and remove the bottom spray arm and run the dishwasher to see if there's water coming out of the bottom pipe, if not, i need to try and see if there's a blockage in the system, or a dodgy valve, could be that the soldering's or the control panel's buggered.
Was this helpful?
Yes
No
Popular Solutions for Siemens 24 in. SE25T250
Questions and Unsolved Problems for Siemens 24 in. SE25T250
Do you recommend Siemens 24 in. SE25T250 Free-Standing Dishwasher?
Answer
Answer
The dishwashers does not wash properly,the water does not come out of the top spinner.If i use a... (More)
Answer
hello there,the time counts down to 1 minute,and goes no further,whats the problem please,you open... (More)
Answer
my cups taste of salt after they have been washed.I have washed stuff at higher temperatures and... (More)
Answer
our sink which is connected to the same as diswasher was blocked when we unblocked the sink the... (More)
Answer
My Sieman's dishwasher won't fill with water but the motor is running even with the door open. Does... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Siemens 24 in. SE25T250...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
