Question about Intel ASUS P4BGL-VM 845GL Chipset Ultra ATA100 MATX CPU Type: Pentium 4 478-Pin (OEM) (59829) Motherboard
Monitor not coming ON
Good day,
When i connect my monitor to my CPU, i get a display that there is no signal. i have checked to make sure that the CPU comes on cos i see the green light, and also the fan rotate.
Please what can i do.
With regards
Paul
  • circlips4rea Nov 24, 2008
    I'll go try it out now cos i even noticed that most of the time when my power cable is connected the system still does not come ON at all. thanks a lot have tot of that n was thinking of changing the RAM.
    get back to u when i'm done with it
    Sergeant:
  • 177 Answers
The monitor is not able to detect any video signal from the motherboard, that means your pc is not starting up. Try cleaning the RAM first. Then clear the CMOS and try to start ur computer again
Posted on Nov 24, 2008
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
No signal detected message on monitor, cpu and monitor are on
Good Day Jboone563!
You need to check if the VGA cable is properly fix to the monitor and video card. Loosen connection or no contacts is the reason for the "no signal" display on your monitor.
This means that there is no signal coming out from the video card, going in to your monitor. If by fixing the VGA connection did not fix it, try removing the video card from the motherboard and then reseat it properly to the motherboard slot.
If this do not resolve the problem, Jboone563, I'm sorry but you will need to replace the video card.
May 26, 2011 | AOpen 19" LCD
How to fix No Display on LCD Display Panel at all?
Good day, For you lcd issue you may try doing these steps:
1. Check if the the power cable of properly plugged in.
2. Check the cable connecting your monitor to the tower or CPU
3. If there's no power at all you can try to change the power cord and also the monitor to cpu cable.
4. You can also plug it on another outlet to make sure that its not your power outlet that's causing this problem
If everything above doesnt work for you, you might consider having it check by a technician or just purchase a new one. Hope this information help you a bit. Have a great day.
May 24, 2011 | CTX Panoview 510 (White) 15.1 in. Flat...
Screen said please check video cable connection?
This is an indication that the monitor is not receiving a video signal from the computer. Check both ends of the video cable - both the connection to the monitor as well as the connection to your computer's video card, and make sure that both are secure. If the connections are secure and the problem persists, buy a replacement video cable. If that fails to fix the issue, try swapping out a different video card.
Mar 02, 2011 | HP Computers & Internet
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
MONITOR NOT COMING ON . RGB NO INPUT SIGNAL .
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
Oct 28, 2008 | Computers & Internet
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
I have a pavillon a6421 uk hp computer when i turn it on the monitor comes up with no vga signal (i have changed the graphics card and it is still the same) have done all the trouble shooting options...
Hi
First Check the power cable of ur monitor whether power is coming or not..
Then remove signal cable (which is connect the cpu) and then switch one the power, check whether any msg is coming in screen.(like no signal or no connection) if it comes means u want to check the cpu or else their is problem in ur monitor..
Connect the another monitor with ur cpu.Whether ur cpu is working properly..
Sep 19, 2008 | Computers & Internet
No signal from cpu
i think you should check if the sync wires are properly connected both on the db15 connector and the main board
Jan 30, 2007 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung 710v no display, video
do one thing remove your monitor from cpu and turn it on only your monitor if check signal cable display is comming on your monitor means you have your cpu problume
thanks
Sep 28, 2006 | Samsung 710V 17" LCD Monitor
Intel ASUS P4BGL-VM 845GL Chipset Ultra ATA100 MATX CPU Type: Pentium 4 478-Pin (OEM) (59829) Motherboard Logo
102 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
