Question about Panasonic Lumix DMC-FZ28 Digital Camera
Concert sound problem...
I recorded a live concert performance just fine but found that songs with a lot of bass high volume caused distortion in the sound. Is there any way to compensate for this?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
You can clear the noisy sound by yourself. I just got help from, and I found there are many news and shows info in it. For more help on music and sports, you can visit the website by yourself.
Posted on Jun 16, 2015
  • Panasonic Master
  • 19,396 Answers
You need to transfer the file into computer, and then clean the audio using a software program.
If you want a professinal tool, download software from:
Steinberg Media Technologies
You can also find some free software with basic sound editing, filtering and cleaning option, see:
Sound Cleaner
Download Sound Cleaner free software
Posted on Nov 24, 2008
I recorded videos at a concert with the new nikon coolpix L810 and the sound on the video is horrible.What is causing the noise in my video? sounds like wind is blowing or a crackling noise
The problem is the microphone on the camera. The mic on the camera is for recording sound in more normal environments. The sound level on a typical concert is much higher than normal, and the mic on the camera just doesn't have what it takes to record sound at those levels.
One possible solution is to record the sound with a dedicated audio recording device, and combine the video and audio in your video editing software.
Jul 02, 2012 | Nikon Coolpix L810 16.1-Megapixel Digital...
Fender Concert II preamp is faint and distorted on 2 channel
It sounds like a job for a technician. There are high voltages in the chasis and the potential for a serious shock to the unwary.
That said, I can suggest several possibilities.
First, make sure the controls aren't causing the problem. Contacts can build up dirt and oxides and block the signal. Try twiddling the controls and see if the problem comes and goes, or if you hear scratchy noises. If symptoms are found, buy a contact cleaner spray, take out the chasis after unplugging and letting it set for an hour, being very careful not to touch any exposed conductors inside. You'll see some holes in the control bodies; squirt cleaner for 2-5 seconds and work the controls.
Also see if the problem happens without the footswitch, and try the channel switches several times - same problem, dirt and oxidation.
Other possibilities - cathode bypass capacitors drying up, and it looks like the amp uses some opto-couplers at various stages.
Nov 09, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Download the tape onto your computer into a software editing program DV's are digital so there might just be something hanging up or dust. Then when you burn your disk make sure that the quality is set on high and have it double check the data before writting. This should collect the loose fragments and put them toghather.
Nov 17, 2008 | Panasonic NV-GS50 Mini DV Digital...
Marching band and live band concerts come out distorted
I'm sorry to say that there isn't a way to make bad audio good. You can sometimes make it a little better but it sounds like yours is distorted beyond help.
Your built-in microphone automatically senses how hard to "listen". Generally, being closer is better but in your case the signal was so loud that your audio sensors "clipped" the sound to protect your circuits. That means there is no signal in those gaps that could even be corrected.
The best you can do is see if someone else had a successful recording.
Nov 17, 2008 | TDK DVM-60L10 10 Pack 60 Minutes Mini DV...
It was working but now ll the songs soun like a concert
Have you tried another pair of speakers? Speaker wire being crimped can cause this problem over time. If you have already tried that then replace the batteries in order to prevent a low battery solution [you'd be surprised--I've even done that before in my MP3 after similar exp. which mines a samsung..]
Let us know how that helps. Thanks for your post and we wish you luck!
Jun 15, 2008 | Coby MP-C883 MP3 Player
put the camera into manual mode from there get into the menu options and adjust the recording volume level.
May 18, 2008 | JVC GR D370US camcorder Mini DV
Sound on Video?
Hey Alymac,
Digital still cameras are not designed to record high quality audio. The mic used to record the audio is probably OK for normal audio situations, but not for difficult recording situations like concerts. To get a good quality video that has good quality audio I would invest in a high quality digital camcorder. What your camera was picking up is all the atmospheric noise that is going on around you. You probably didn't notice it because a concert is usually a loud environment. To get a good quality recording of a concert you would need a mic that focuses where it picks up its audio from instead of from all sounds surrounding you.
Go Ahead. Use Us.
May 08, 2008 | Canon PowerShot S3 IS Digital Camera
Panasonic Lumix DMC-FZ28 Digital Camera Logo
228 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
