Question about Indesit W 123 Front Load Washer
Program selector knob keeps turning
It is getting increasingly difficult to get the washer to start correctly. I have tried a number of different start sequences, including:
1. Switching mains plug socket on, selecting program, pressing the on button (proper start sequence).
2. Switching mains plug socket on, selecting the reset of the program section I want to use, pressing the on button and waiting 30 seconds for reset, switching off button, selecting the required program, switching the on button.
I now don't put any washing liquid/powder in until I'm sure that the program is working correctly.
Your help will be greatly appreciated.
Yvonne
  • martinsetal Dec 04, 2008
    Thanks for the help, will keep searching
  • Indesit Master
  • 3,463 Answers
Difficult to pinpoint problem from symptons.
Try this link, there is a lot of information here which may help you.
www.washerhelp.co.uk/diy-repair-help
Posted on Dec 04, 2008
How i get off demo mode
Hello Mark, thank you for your inquiry!
I understand that your Electrolux washer is in demo mode and you need help in getting it out of it. In order to get your washer out of demo mode you would need to turn the cycle selector knob to spin only/time dry. Press start then the cancel button. Activate the control panel by turning the cycle selector knob to spin only/time dry cycle. Press and hold the cancel button with the soil level/extended tumble button (third button from the left) for three seconds. This should deactivate demo mode on your washer. If you continue to experience issues with your washer please comment back and reply with your model number. You can locate the serial tag (which lists your model number) on the door frame of your washer. I hope this information is helpful to you. -Matt
Dec 16, 2015 | Electrolux Washing Machines
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
Pressure foot pressure control
The pressure foot knob had some problems. on this model. The solution was to remove the covers and the e clip that holds the knob in place. I install a belleville spring washer on the knobs shaft. This extra tension keeps the knob from turning when the sewing machine vibrates. This may be more difficult than most consumers want to attempt.
Oct 13, 2013 | Husqvarna Scandinavia 100 Sewing Machine
My washer test runs great I hear every thing working correctly but when I do laundry it doesn't spin. How can I fix this issue. I am getting an error code f7 e1
I know how frustrating it can be when appliances do not function properly.
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
I hope this is helpful. Post back your results.
Click here for image
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Washer will not start
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc...
If there are no error codes stored, you will need to replace the control board. Here is a link to the part.
Oct 17, 2012 | Whirlpool Washing Machines
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
Hi there, I have a Euromaid WM5 and suspect it was overloaded as it stopped near the end of the cycle. We turned it off at the power as it wouldn't reset and couldn't get clothes out. It has been off...
I think, that if you want to cancel the program, you have to select correct program on selector knob. When turning the knob observe the display. When correct program is selected, it will show spin speed and temperature.
I have also managed to reset the machine by entering service mode. Turn it off, select Cotton program. While keeping Start/Cancel button pressed, turn it on. It showed E 05, then whole display started blinking. Using the same button it started spinning. After turning it off and on again, the machine was reseted.
Feb 21, 2011 | Washing Machines
Spin cycle doesn't cut in
turn program knob to spin and hit start then hit cancel within 5 seconds hold down options and start/pause button this will put you in the self daignostic test
and hot water should enter through the detergent compartment
cold water should enter through the bleach compartment
will activate and cold water should enter through the
the loading door can be opened.When the door is
position. The washer will fill and tumble. Once
tumbling has started, the Boost Heater (if so
equipped) will turn on.
position. The drain pump & door lock solenoid will
activate and the washer will operate in high spin.
then on the last turn it will give you the other error codes it has that code is giving usually is caused by a different code to clear the codes
• Turn the program knob clockwise 7 clicks from the
Start Position. The control will signal the last error
code.
• Press and hold the Options and Start/Pause
buttons for 3 seconds. The code will be cleared. you really need to clear that code first to do the test but it can be done in the daignostic test skip the rest first go straight to the 7 clicks and clear the code but dont open the door during the test otherwise it will give that code after you get it cleared go to the spin spot on the knob and keep turning clock wise to go through the test but give it at least 3 seconds for each test then it should display a different code and what ever it is email me and i can help you out at that point nick_bradford2003@yahoo.com i have alot of experence with appliances
Jun 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Program Selector Knob keeps turning
when the knob keeps turning, it is giving you a code by the blinking red light. count the blinks. i have a manual to explain what the codes mean and how to test the parts
Jan 07, 2008 | Splendide Comb-O-matic 6200 Non-Vented...
Program selector know is broken
First thing i would do if it is not selecting a different cycle is take the knob off and check to if the inside of the knob is broken and hust turning on the shaft, other then that it proberly is electronic replacement.
Oct 27, 2007 | Miele Novotronic W1930 Top Load Washer
Indesit W 123 Front Load Washer Logo
252 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
