Big circle in the middle of the screen of my Big Screen TV
I just received a big screen TV for free. when turned it on and adjusted the settings after cleaning it out, i found that there was a big circle in the middle of the screen. so i cleaned the RBG projection lenses, and the mirror that projects the image onto the TV. when that did not help i took the screen off. i noticed the screen was encoded with tons of tiny unseeable circles. i tried to clean them but it did not affect it. any sudgestions on how to clean it or fix it? and if not where i can get a new 52 Inch screen for it.
  • tehcracker Dec 01, 2008
    same problem
4 Suggested Answers
SOURCE: Cleaning mirrors and lenses on Sony big-screen projection TV
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
Posted on Sep 16, 2008
SOURCE: Panasonic 52" DLP TV Red circle on top right of screen
please read the blog
Posted on May 01, 2009
ladywinn
  • 5138 Answers
SOURCE: have sony wega 52" screen
You can try replacing the Lamp First,sometimes this will Fix this problem ,but if it doesnt then you are going to have to replace the Optical unit Block/Light Engine PN# A-1084-660-A
Encompass Parts 1-800-638-3328
UED 1-800-648-6657
PTS1-800-844-7871
Mats Electronics for Lamp $99.00 1-800-628-1118
Posted on Nov 09, 2010
How to fix the big dark circle in the middle of the screen
I think you may be having a problem with the projection bulb.
Jun 09, 2014 | Sony VPL-ES1 Multimedia Projector
There are light blue dots on the screen and now there is a big circle in the middle of the screen that is a different tint than the rest of the screen
Optical board is bad. Sony LCD Rear Projection TV Problems is Sony's link to all the issues of this TV. If you are the original owner of the set, contact Sony and climb the ladder if necessary. This has been a big problem for them and have resolved 3 class actions so far and have more headed their way. You could possibly get it repaired for free or a minimal charge. It's a 900.00 part! at cost... Hope this helps. if you need more info, post a comment and I will help further.
Jan 04, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Big black block in the middle of tv
Check youron screen menu setting for Closed Caption (CC) and turn it off.
Oct 29, 2009 | Philips Magnavox 27MS343S 27" TV
Big Screen Projection receiver TV vertical pincushion problem
the aliment is out need a profession to adjust it for you
Jul 24, 2009 | Televison & Video
Free big screen, is it worth it to fix?
take the front cover off.two hidden screw at each corner or on the sides .now take off cover in middle of set.two the right you'll find a small box , it will have 3 adjustments on the top and three more at bottom.the bottom ones are your screen controls.the middle is your green and on the right is the one you turn counter clock wise.warning ...turn that control a hair .that will solve the problem
mr.tv.inc
1-866-217-6788 harry
Feb 18, 2009 | Sony KP-57HW40 57" Rear Projection...
Bush tv has a circle on screen like looking thru a telescope
HELLO
Funnily enough I have been given a 21 inch standard Bush set with the same problem!
It's a DEGAUSSING fault. This means the deguss circuit in the TV is not operating as it should - probably a faulty positor. When you switch the TV on (NOT FROM STANDBY) the circuit that removes magnetism from the screen does not work correctly.
Switch it off, unplug the set from the mains for 30 minutes or so and try it again. If there is no change, contact a TV repair centre.
Make sure there are no hifi loudspeakers next to the TV or a radiator as this can have an effect too.
ALL THE BEST! (:-)
Jan 06, 2009 | Bush 5693D 24" TV
The screen
Hi
you have defective Horizontal linear! or defective deflection yoke! this need to replace the yoke!
Thanks!
Dec 27, 2008 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Tv rainbow in screen
The picture tube has become magnetized, possibly by someone getting a magnet to close to it. You can de-magnetize it using a strong magnet (cow magnet or similar). Place the magnet as close the the screen as possible without touching it to the screen. Starting at the middle of the screen and slowly (not too slow, about one full circle per second should do) move the magnet in a circular motion. With each full circle move the magent twards the outside (making a larger circle) as well as moving it farther away from the screen. Using a magnet will not harm the screen, so play with it and you'll soon get the feel and will see what you need to do.
Tv's have a circuit built in to 'Degauss' (demagnetize) the screen each time you turn it on, but this will only work if the set is 'Cold'. If the set is left off for 2 hours (to cool doen) and does not demagnetize when you turn it on the circuit is faulty.
Jul 21, 2008 | RCA TruFlat 27F520T 27" TV
Image has big yellow
Hi Zenmast
This is a burnt LCD that will need replacement. If the circle is yellow on a white screen , then it is your blue LCD that will need replacement.
Apr 22, 2008 | SharpVision XV-Z1U Multimedia Projector
Tv has a big black in yhe middle,does that mean that the picture tube is going out
no that is not the sympton of picture tube failure. please give the details of your problem so we will get you solution.
Oct 07, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Televison & Video Experts
