Question about Polaroid PDM-0722
Lcd display is upside down
I have no idea what I did but now my lcd display is upside down and I can't get it back - help!!!!!
Here is the answer: hold down the "MODE" button while a DVD is playing. http://polaroid.custhelp.com/cgi-bin/polaroid.cfg/php/enduser/std_adp.php?p_faqid=2863&p_created=1123860923&p_sid=-SRglRFi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9NDoyJnBfcm93X2NudD0zNCZwX3Byb2RzPTIyOCwzNjksNDQ4LDQ1MyZwX2NhdHM9MCZwX3B2PTQuNDUzJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTI*&p_li=&p_topview=1
Posted on Jul 05, 2007
SOURCE:
Upside down display
I have read that to invert the LCD-screen you just flip the polarisation-plate (the plastic film that sits over the LCD display) 180º, that is, upside down.
Did you or someone opened your calculator? He might have reassembled it wrong. Or was it a prank?
If that was not the case, your best change is to reset the calculator and see if it solves your problem.
To manually reset your graphing calculator:
  • Remove all AAA batteries.
  • Remove the back up lithium battery.
  • Leave the unit empty for 5 to 10 minutes.
  • After the 5 to 10 minutes, place all the batteries back into the graphing calculator.
This process should restore the graphing calculator to the factory settings.
Good Luck!
Sep 10, 2009 | Texas Instruments TI-73 Explorer...
Sceptre 40" 1080P LCD HDTV Display Upside Down
Sceptre X37sv-Naga 37 in. LCD Television
Screen is upside down as I type
Wow. Just wow. How did that person do that?! Anyways, try resetting ALL of the memory, and see if that helps, if not, ask the student what she did so that it can be reversed (probably by doing the same steps in the opposite order.
May 21, 2009 | Texas Instruments TI-84 Plus Calculator
Upside down display
it could be a number of things. One, it could be your graphic card settings, have a look at them. Two, i forgot but therer is a shortcut to maing your screen turn upside down. Have a look at the settings and i hope you find how to fix it.
DigicalJAi
May 19, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My DELL Monitor shows the picture upside down
Try holding down the CTRL key + ALT key and tap on the Up arrow key once to rotate the display back to orginal orientation
Thanks
proton
Mar 22, 2009 | Dell E193FP 19" LCD Monitor
Hyundai flat screen monitor upside down display help?
There are 4 screws on the back that connect the monitor to the stand. Remove them and turn the monitor right side up and replace the screws tightly. OR you can change your layout in your video card settings.
Nov 20, 2008 | Hyundai L91A 19" LCD Monitor
Upside down display
press alt+ctrl+upper arrow key it will help and let me know
Sep 10, 2008 | Dell Inspiron 6400 Notebook
Lexmark x644e LCD Display Upside Down(Inverted)
Hello there,
I've seen this before. The X64X series with this inverted display seems to work fine (printing,scanning,faxing..) the reason for this is still unknown. But I've got it fixed twice by resetting the NVRAM on this MFP. If you are unsure of how to reset NVRAM, please follow the instructions below:
1.Power off the MFP
2. Hold down the 6, 7 and 8 buttons down and turn the MFP On.
3. Please hold down the buttons till it reads resetting factory defaults and then release the buttons. The MFP should now come back to ready status.
Please check out if this solves the issue, If not the machine would need a hardware service.
Merry Christmas!
Dec 18, 2007 | Lexmark T632 Laser Printer
Lexmark x644e LCD Display Inverted(Upside Down)
first thing i would do is update firmware
http://support.lexmark.com/static/229-1-0-530.html
Dec 18, 2007 | Lexmark X644e All-In-One Laser Printer
Sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
Nov 06, 2007 | Sony Handycam DCR-SR40 Camcorder
Televison & Video Logo
195 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
