Question about HP Officejet 5610 All-In-One InkJet Printer
It shows paper jam without a paper - HP Officejet 5610 All-In-One InkJet Printer
  • 1 more comment
  • Anonymous Nov 24, 2008
    it shows paper jam without a paper problem
  • Anonymous Nov 25, 2008
    intermittenntly I get a paper jam message .After re-booting, turning on and off, and unplugging several times it will straighten out and do fine through ten or twelve print jobs and then do it it again.
  • natesmith103 Dec 09, 2008
    After multiple times of reseting and unplugging the printer in still notifing that there is still a paper jam.If there is any other solution , please post as soon as possible, thanks guys.
  • 31 Answers
Fiend your solution direct from hp. Here is your solution...
Posted on Mar 19, 2009
  • 105 Answers
Please refer to the below web document:
Posted on Nov 25, 2008
2 Suggested Answers
  • 199 Answers
SOURCE: show paper jam without actual
1.check the back cover is open and the green levers are down. the front cover remove the cartridge ,you can see a green lever ,just lift it up and see any paper pieces are there.
Posted on Aug 05, 2011
Printer show paper jam without paper in it
hp deskjet 3600 series
Printer show paper jam without paper in it try blowing it out with compressed.
Aug 12, 2016 | hp deskjet 3600 series
Why epson l130 printer shows paper jam message while there is no paper inside?
The sensors could be broken or there may be something else stuck inside, sticky labels, small bit of paper?
Have you opened up all areas you can without tools with the power off for your safety?
If there is nothing found it may need a repair.
Dec 08, 2015 | Epson Office Equipment & Supplies
Without paper jam, the system is showing paper jam ? why ?
try to run Maintenance from windows control panel, also open all compartments on teh printer and look to see if there is a fragment of paper stuck there.
Jul 22, 2014 | Canon LASER SHOT LBP-2900 Printer
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
Am repairing a canon ir1020 which shows paper jam for any single copy.though paper is completely delivered out of the fuser ,but the red in response to paper jam still flashes.I need an assistance.
Sounds like the fixing exit sensor flag is missing or broken. I would look into that and just a note... I had a strange jamming problem with one as well. It turned out to be the registration clutch. I cleaned the clutch and it worked......
Sep 01, 2012 | Canon IR-1022 Copier
It wont print, says paper jam, yet there is no paper stuck anywhere? any suggestions?
Try removing the cartridges and drum and clean the big grey roller as this picks up paper and if not it will show a paper jam without paper being in the machine!
Good Luck!
Jan 17, 2011 | Samsung CLP 300 Laser Printer
Erroneous paper jam message. Unit sat without paper or cartridge for 3 months. When it was plugged back in without paper, the paper jam error shows up.
it seems that the head cannot move from its initial position to the paper margin position. check for any objects in the paper path. Put a paper (not more than 220 gsm) in the paper tray and press eject button. Push paper to go inside the printer. It will come out with the paper or object in the path. If it did not give solution call the service call centre.
Aug 14, 2010 | Epson PictureMate (C11C556001) InkJet...
Comes up with paper jam. Open cover, remove drum and removed jammed paper. Had a look no jammed paper, looked at the back fuser area, no jammed paper. Removed paper try, no jammed papper. Can u help
If your printter is showing the message even after you have made sure that there is no paper inside the rollers , it is sure that the sensors- optocouplers- or the input amps for the sensors are defective. Youmay need to check on these individually to confirm. Identify them justt placed beneath the rollers take in guides. Check if thedetector is emitting even without the paper. use a multimeter to check of rvariation of votage with paper or without paper to confirm. hope you try this out and confirm. Good day,
Aug 11, 2010 | Brother MFC-8460N All-In-One Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
