Question about Neff H7871 Convection/Microwave Oven
Replacing a bulb on delonghi combi oven ED8525S-SBD
There is no obvious way of getting at the bulb, there is a panel you can remove but dont let you anywhere near the bulb, any advice you can give me wouldbe very much appreciated, i have looked in the manual but is of no help at all.
thanking you in anticipation,
bryan rogers
  • Neff Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Nov 24, 2008
My micro/oven/grill (ed8525s-sbd on rear) will not turn on. after using the oven feature around 20 seconds after it had done it tripped the kitchen sockets and set the house alarm off. the fuse in the plug...
It's likely that some part of the microwave has gone short circuit and blown the main fuse. The fuse is a 7000 volt glass encapsulated inline fuse housed inside a tubular plastic case about 2 inches long.
Renew the fuse and switch on. Look out for anything that is not functioning and replace that part, eg, fan, light, turntable motor etc.
Jan 29, 2014 | DeLonghi MW 605 Convection/Microwave Oven
Microwave delonghi
Check input power board and fuse.
Dec 01, 2017 | Microwave Ovens
Light bulb
The first step is to unplug the oven before changing bulbs!
You didn't mention your brand and full model number, so we'll have to give you a very general answer.
A diagram which helps you find & replace many GE cooktop and cavity light bulbs is here http://031d26d.namesecurehost.com/mwd/ge_lamp_replacement.jpg
You'll need to remove the outer cover (wrapper) to get to the bulb.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Dec 27, 2012 | Microwave Ovens
Interior bulb out in microwave oven (built -in)
It all depends on that all-important model number. So without that, we can only give a broad, generic answer.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://031d26d.namesecurehost.com/mwd/ge_lamp_replacement.jpg
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph, except to unplug the oven.
Bulbs (or 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Nov 27, 2012 | Microwave Ovens
Where can I get user manual for Delonghi Touch control microwave oven ED8525S-SBD
You can download the complete instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 23, 2010 | DeLonghi MW 605 Convection/Microwave Oven
How to replace light bulb in Quasar microwave oven model MQS1236H
Could that be MQS1263H?
Either way, this owner's manual may be close enough.
If it's not addressed in the manual, and there's no obvious cover on the side or back, then you'll have to remove the cover of the oven to change it.
If it's an owner the range type, you can likely get to and replace the light by just removing the grille or possibly the control panel assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's a counter top unit, you will need to remove the outer cover and look for it near the magnetron cooling duct on the right side.
Before doing any disassembly, please see these files: safety disassembly.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
You can also order Panasonic parts here.
Dec 25, 2009 | Microwave Ovens
I have a Delongi Microwave combi and need to locate the lamp, the model is AC930AMQ, so far I cannot see the lamp anywhere and need to replace it. If it is internal I have no prblem with that as I am an...
I removed the outer case by three posidrive screws and two security screws. The lamp is located in a downward position on the left hand side looking from the back. A normal 25watt 300c ses bulb is suitable so no need to buy original if you don't want to. Take care before removing cover by unplugging the unit and only work on the lamp area as there is high voltage present charged in the capacitors !
Oct 17, 2009 | DeLonghi Microwave Ovens
I have been given a DeLonghi 850 Microwave but have no instructions - is it possible to get some. It has a serial number of ED8525S-SBD. I tried to heat something but it wouldn't think I must be using the...
try looking for your manual here: http://www.delonghiusa.com/index.php?texts&pid=10
If you can not find it, try calling their customer service, and ask them to send you a manual!
help@delonghi-csservice.com
1 (800) 322-3848
Sep 09, 2009 | DeLonghi Microwave Ovens
How to change light Daewoo KOR - 63F7
If you don't have your instructions, please reply back with your brand and model number.
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Aug 19, 2009 | Daewoo Microwave Ovens
It turns on ...lights up but doesnot heat or warm the food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 17, 2009 | DeLonghi MW 605 Convection/Microwave Oven
Neff H7871 Convection/Microwave Oven Logo
827 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
