Question about Nokia 2630 Cell Phone (Unlocked) - Black
Problems with connecting to internet
HI!
I have recived all configurasion setting from my operator ("VivaCell MTS" Armenia), when i want to connect with standart web app it loading then says "Link not available try again", i tried to connect with Opera Mini v4.0
but there was the same problem!!!!!!!! i have another Nokia, Nokia 6300, and all setting i recived are ok, i even set them manually and it all worked, i tried to set mannually on my Nokia 2630, but noting works!!!!!!!!!!
Thank you for helping!!!!!!!!!!!!!
  • 32 Answers
U will call ur operator customer care so explain to them about ur phone and tell them the model number and the type of ur phone
Posted on Nov 27, 2008
Router operation without Internet connection.
Yes i can help you with this
You dont need internet connection
Feb 12, 2008 | Linksys Wireless-G WRT54G Router
I want connect this mobile to pc for internet connection. how to connect with internet via mobile. for expect settings
As you said me your using Samsung GTB5702 you can connect your mobile to your pc and you can use the internet.You need to instal pc suite to your system after installing this you need to call the customer care and tell them that i need to connect my mobile to system and i need to use internet in my system they will tell you to send a message from your number after sending this message you will recive settings save that settings switch off your mobile phone for a while after that connect your mobile to your system.At that time call customer care once again and tell to give settings for my system they will tell you to change some settings in your computer after saving you can use internet in your computer.
Jun 15, 2011 | Samsung GTB5702 Cell Phone
Mblaze broadband device but it is giving the error as "cannot access serial port, make sure you have appropriate permission" I am using a Dell inspiron 15R laptop
That notification ,,if it is a notification,,,means you need extra "authority" to enable the function.This you will have to configure in your settings depending on your operating system
Mar 10, 2011 | Computers & Internet
Hi I have been trying to connect Mblaze plug to serve to my Dell laptop but it is giving me error as "cannot access serial port, make sure you have appropriate permission ". Previously,it was...
hello ,
nothign to worry about , you just try to change the usb port , i mean try a different usb port on your laptop it will search for the drivers and it should work , still if you are facing any problems ,goto control panel -add/remove programs uninstall your mblaze software,,then re insert your device it will again install the software and this will definately solve your problem .
Regards.
Jan 06, 2011 | Dell Latitude D600 Notebook
Solution of error with yahoo 81003016
Click Messenger tab. Make sure the program window is open.
Then, click Connection Preferences. It will open up a window for you to work on setting up your connection.
On the Connection options, you can either choose:
1. Connect directly to the internet. (This is the recommended setting if you never had connection problems.)
2. Connect via a proxy server. (Use this option if you are behind a firewall and know your proxy server settings.
From the Internet connection option, you can choose among these three–Dial-Up, Broadband (DSL/Cable) or High-speed (T1/LAN). Once you’re able to select all your options, click Apply then click OK.
You may try switching connection from Connect directly to the internet to Connect via a Proxy Server and choosing HTTP Proxy then click Apply. This should work for you.
Good luck.
Jun 25, 2010 | Microsoft Windows XP Professional With...
My pc recived fax but few munites than sand that recived fax is fail please help
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab25
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Connection problems
Maybe you need a faster Broadband speed. The speed you are on now mayb not be able to handle sharing it with other computers and has just broken down
Jan 26, 2009 | Microsoft Xbox 360 Console
I have a htc x 7500 advantage i ve installed a new windows on it after doing that my phone doesn t recive any GSM signal what can i do to fix it? where can i get the software for the phone application?...
You can connect to the Internet through Wi-Fi, GPRS, Dial-up, or Work connections(such as VPN and proxy connections). If you are encountering problems :
.Open the Comm Manager and make sure Flight Mode (or Airplane Mode) is turned off.
.Make sure the connection method settings are correct before accessing the Internet.
.Make sure the connections have been activated (e.g. Bluetooth, Wi-Fi etc.).
Jan 26, 2009 | HTC Advantage X7500 Smartphone
Picture messages
Hi there!
Make sure your subscription covers the desired service(s), and that the selected carrier (e.g. GPRS/EDGE) is available in the area. If you still have problems sending or receiving MMS (picture messages) or accessing the mobile Internet/WAP on your phone, you probably need new settings installed. Please try to contact your operator for the correct settings.
Cheers!
Dec 29, 2008 | Sony Ericsson w580i Cellular Phone
Nokia 2630 Cell Phone (Unlocked) - Black Logo
85 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
