Question about Xante Accel-a-Writer 3N Laser Printer
E fuser message
What does E: FUSER message on xante 3n mean?
  • leonard594 Nov 24, 2008
    What is a E:FUSER error and how can I correct the problem?
    E:FUSER is displayed when the temperature sensor inside the fuser does not read the correct temperature (too high or too low).
    • Turn off the printer for 30 minutes to allow fuser to cool and restart.
    • If not corrected - reset the printer by holding ONLINE and TRAY SELECT on the front panel during startup (when the black bars start across the screen for Series 4). It should display RESET if done properly.
    • If not corrected - replace the fuser unit.
    Problem Solver:
  • 5 Answers
Xante screenwriter 5 will not go thru the fuser when printing. Paper seems to roll there. manual does not give instructions on removing fuser and visual inspection shows no paper caught in path.
Check for media jams in the paper exit area under the fuser cover.
SEE 8-13 for diagram of fuser cover location.
http://www.xante.com/download/Legacy-Color-Products/Colour-ScreenWriter-Series/Colour-Laser-Series/ColourLaser/Manuals/Troubleshooting%20-%20English/cl_troublesh.pdf
Hopefully this is all it is other wise it may be more sinister like the fuser roller has fused together -
I have had this happen on another printer . Because I did not remove the power before I removed the fuser unit in a different model and make of printer. And fused the rollers together like melted together in the fuser. I think you would get an error code if this was the case !
Apr 10, 2018 | The Office Equipment & Supplies
How do i fix the little black piece that broke off of the fuser exit sensor on my Xante Ilumina?
Amanda,
The problem is related to the paper exit assy. Their is no problem with your fuser assy. Take a look at the exit document related to your problem. Usually that is cause when removing a paper jam, that switch flags break for pulling the paper in the back direction. You would have to replace the paper out exit swicth black actuator.
Oct 03, 2014 | Xante Ilumina® 502 Laser Printer
Xante fuser reset fuse
That fuser is behind the cover of the fuser. Not easy to get to it, I do not recommend taking it apart unless you have a new one standing by, cause you are going to need it. Drum and transfer belt ok not so with the furser assy.
Jun 24, 2014 | Xante Office Equipment & Supplies
How do I replace a fuser for a Xante Accel-a-Writer 4G?
dear please find back cover and open it found big unit of printer called printer fuser assembly.removed it carefully you need one Philips screw driver,losses the two screw after that you removed screws slide it right side if you stand back of the printer,however after remove the fuser assembly you can installed it new in the Xante 4G printer when you install slide fuser to left side and alignment carefully,hope you understand.
thanks.
Jun 19, 2014 | Xante Accel-a-Writer 4G Laser Printer
We bought a new iMac, running MacOs 10.6. Where can I find a driver for Xante Accel-a-Writer 3N Laser Printer
Go to this link and under Drivers, English select MAC OS X and download the drivers: http://www.xante.com/support/aw3ndn/
Sadly, the application drivers for MAC OS 10.6 are mot supported for this printer.
Feb 10, 2011 | Xante Accel-a-Writer 3N Laser Printer
Good day I have a Xante Ilumina 502, when i print on 300gsm and up there is a magenta background. How do i solve this
Your settings are incorrect, adjust media type and media weight. This settings adjust the temperature of the fuser. If fuser to cold you will have ghosting and fuser to hot image will stick to fuser.
Mar 31, 2010 | Xante Ilumina® 502 Laser Printer
Front paper jam
Always try to remove a paper jam without tearing the paper.
If torn, make sure no scraps of it are missing.
Lokk for any tiny scraps, esp stuck on paper path sensor.
Apr 17, 2009 | Xante Accel-a-Writer 3N Laser Printer
Fuser is bad...actually, the paper jam sensor is bad. can I use a fuser from a different printer
Yes, most likely they do. I don't believe there is much if anything that differentiates one toner from another other then the size of the roller and the shape of the cartridge. If these are the same and given that they use the same fuser, I would definitely try it.
Aug 08, 2008 | Xante Accel-a-Writer 4G Laser Printer
Screenwriter 3 Fuser Problem
go here to the 3N section, email these guys and see if they can help you.
hope this helps
thanks for your rating
Jan 08, 2008 | Xante Accel-a-Writer 3N Laser Printer
Xante Accel-a-Writer 3N Laser Printer Logo
480 people viewed this question
Top Xante Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Dudeman321
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
