Question about Microsoft Windows Vista Ultimate Edition
Blue screen when the system is on, if we are not using for 10 minuter then the blue screen occur and the system will restarted.....
  • 177 Answers
May be the power managemnt is causing problem.
Try the following:
1) Open Control Panel ->Power Option
2) Under Power Scheme, Make sure that
All the options (i,e Turn Off Monitor, Turn Off Hard Disks, System Standby, System Hibernates )
are set to Never. You also need to disable the Screen Saver if any.
Posted on Nov 24, 2008
Blue screen unable to restart windows10
A stop error (also called a "blue screen" error) can occur if a problem causes your PC to shut down or restart unexpectedly. When you experience this type of error, you won't be able to see things like the Start menu or the taskbar on the screen when your PC is turned on. Instead you might see a blue screen with a message that your PC ran into a problem and needs to restart.
If you see a stop error while you are upgrading to Windows 10, setup will automatically go back to your previous version of Windows.
If the error continues, try to fix it by removing software or hardware.
Sep 22, 2017 | Blue Computers & Internet
How to restore my dell latitude D610 back to factory settings
turn on computer go into os in programs look for system tools for restore of your unit, as with most computers it will depend on the os you are using ,with xp where computer comes on and you see the blue bar with at top of screen press <Ctrl><F11>,if not pressed in time you start all over, click reboot in the following step, screen appears, click Restore, next screen, click Confirm. Restore takes maybe 6-10 minutes, When prompted, click Finish to reboot computer, computer will shut down when prompted, click yes, computer will restart, click next System Restore will appear and the computer restarts, after it restarts, click OK. hope this helps.
Dec 05, 2011 | Dell Computers & Internet
1. Click Start, Right click computer and click properties.
2. Click advance system settings, click advance tab and click the settings button under startup and repair.
3. Uncheck automatically restart under system failure.
4. Please provide us the error code, eg: 0x0000000 if the Blue Screen reoccurs.
5. Run hardware diagnostics for possible hardware issue.
6. Run "Chkdsk /r" under command promt and restart pc after scheduling it.
7. Run "sfc /scannow" under command prompt after the computer restarts.
8. Update your system drivers by going to your OEMs website.
Jan 20, 2010 | Computers & Internet
How do I restore my dell inspiron 2650 to factory defaults?
If your system is PC Restore Equipped, it will show show a black page with a blue bar across the top after the Dell Splash Screen. the bar will have in White letters. If you see this page for about a second during the boot process, the system is PC Restore Equipped. At the page with the blue bar, press CTRL+F11 and that will initiate the restore process. Providing the image is not damaged, then restore process takes about 20 to 30 minutes and will return the system to out of box configuration. If there are any errors or if the PC Restore page is not available, then you'll have to do a clean install of Windows using the Dell Windows XP CD that came with the system, then load drivers and applications.
Oct 04, 2009 | Dell Inspiron 2650 Notebook
My F11 key wont work it wont go to recover system. I been having problems with my ip address
To use PC Restore:
1. Turn on the Computer. During the boot process, a blue bar with appears at the top of the screen.
2. Immediately upon seeing the blue bar, press <Ctrl><F11>. If you do not press <Ctrl><F11> in time, let the Computer finish restarting, and then restart the Computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3. On the next screen that appears, click Restore.
4. On the next screen, click Confirm. The restore process takes approximately 6–10 minutes to complete.
5. When prompted, click Finish to reboot the Computer.
NOTE: Do not manually shut down the Computer. Click Finish and let the Computer completely reboot.
6. When prompted, click Yes.
The Computer restarts. Because the Computer is restored to its original operating state, the screens that appear, such as the End User License Agreement, are the same ones that appeared the first time the Computer was turned on.
7. Click Next. The System Restore screen appears and the Computer restarts.
8. After the Computer restarts, click OK.
Good Luck!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Dell Computers & Internet
Dell optiplex gx270 serious error!
it might be due to your new hard drive, plz check the ram also
Jun 22, 2009 | Dell OptiPlex GX270 PC Desktop
I have a hp pavilion dv6000, when I start the computer windows go up but in a few minutes the screen go to blue and restart again and very slow.
there are alot cause of blue screen and auto restart,,1. some part damage or bad, 2. Operating system damage,3. if you installed some program not compatible in each other files system..
To Do....
chech the hdd..2. use another hdd, if the same, remove the cd room drive. use external cd or dvd room drive..
Jun 06, 2009 | Computers & Internet
Error is occured.
Blue sreen problem occurs either faulure of Hardware or software and solution is right the message which is displayed on blue screen so you need to look at message once and follow the procedure according to blue screen.
if you are not aware of it then please post back the message which appears on blue screen.
and vote all answeres.
Mar 04, 2009 | Microsoft Windows 98 for PC
Blue screen
Could be something to do with your channels not tuned in propperly or your signal is being lost.
Sep 30, 2008 | Sony KP-57WS520 57" Rear Projection...
Microsoft Windows Vista Ultimate Edition Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
