SanDisk Sansa e250 MP3 Player
Problem for SanDisk Sansa e250 MP3 Player
Help! my sansa wont turn on.. but the blue ring is still glowing
By kesha on Dec 30, 2006
is there a way i can just reset it or to get the screen back on???.. i took it back to here i got it from (yesterday) and they told me they wouldnt take it back i soo i need help fixing it pronto!! im still charging it and still noo screen
Clarification Request
Posted by seijuni on May 17, 2009
Solution link . . .
http://www.Sansae250MP3Player.com`
Same Problem
Nov 27, 2008
-   Me too!-   daviddotcom
Nov 23, 2008
-   this happend to me and i hit the player on my hand and the screen turned on but you coulnt see anything
-   Guest
Jul 01, 2008
-   is jus exactly the same problem-   juanse
Jun 22, 2008
-   my sansa player is not turning on....-   mits_248
Jun 21, 2008
-   Hi,
on Jan 29th 2008 I bought a REFURB SanDisk Sansa e250 Rhapsody.
I've been using it for music and it has worked just fine... I tried to look
at the Sansa video demo today, and the thing flipped out! The demo is on
the unit, so it should not have done this, but now none of the buttons work and nothing I do will bring it back.
-   Guest
Best Solution
posted on Jun 20, 2008
Very Helpful)
Chel08
Rank: Apprentice
Rating: 97%, 18 votes
My sansa 260 has had the blue ring glowing and no screen for a while and I tried all the repair software and none of it worked because my sansa would not connect to my computer. I used the 15 second trick to turn it off, put it on hold then opened the back. Above the battery in the back is a black rectangle which was out a little so I pushed it back in took the battery out and put it back in and when i closed it and turned it on the screen was back! Works perfectly now
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #2
posted on Dec 31, 2006
Very Helpful)
chrism
Rank: Apprentice
Rating: 96%, 60 votes
I was told to hold the menu/power button for 15 to 20 seconds and it should switch off. Then you can use it as normal. Try this.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Apr 26, 2007
Helpful)
Guest
Rank: Apprentice  MP3 Players  Expert
Rating: 0%, 0 votes
dope thanks, i bought mine off a frend whats the cable you use to put in ur comp i need one
Solution #4
posted on Jan 16, 2007
Helpful)
Guest
Rating: 0%, 0 votes
Worked for me!
Solution #5
posted on Mar 20, 2007
Helpful)
Guest
Rating: 0%, 0 votes
I just purchase and sansa250 and I was unable to add songs on it but i was able to do it on another computer that detected it. But when i tried it again on the computer that didnt detect the screen went white. So I came online to get some solution on how to get it back running and i used the 15 to 20 sec hold on the power button and it worked thank god for computers where we can communicate with people with out having to call a suppoet line
Solution #6
posted on Mar 18, 2007
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
worked for me aswell....your a genious chrism
Solution #7
posted on Feb 11, 2007
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
I'VE BEEN LOOKING EVERYWHERE FOR THIS ANSWER!!! THANKS IT WORKED GREAT!!!
Solution #8
posted on Jan 01, 2007
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
I had the same problem and this really worked!!!
Solution #9
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
THANK YOU! Just went into a total panic as my Sansa would not switch on and didn't know why!! Woo-hoo - was totally getting upset thinking yet another MP3 player down the drain!
Solution #10
posted on May 21, 2007
Somewhat Helpful)
krp138
Rank: Apprentice
Rating: 76%, 5 votes
I had my sansa since christmas and this was the first time i had this problem...thank you so much. I was so sad that it wasnt working b/c i love my sansa.
Was this helpful?
Yes
No
Solution #11
posted on Sep 30, 2008
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
AWESOME. I thought my Sansa e250 was "bricked" and totally useless, but this solution worked like a charm. Rose it from the dead & brought it back to life. I have every file back and in tact. Thanks a lot.
Solution #12
posted on Apr 07, 2007
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
OHMYGOSH THANK YOU SO MUCH LIKE HOLDING THE MENU BOTTON FOR LIKE 15 SECONDS OR SO ACTUALLY WORKED:) LIKE I WAS HAVING A PANIC ATTACK BUT THANK YOU SO MUCHH LIKE SERIOUSLYY. I JUST GOT IT YESTERDAY AND IT ALREADY DID THE WHOLE NOT TURNING ON THING.
Solution #13
posted on Apr 19, 2007
Somewhat Helpful)
siddy
Rank: Apprentice
Rating: 67%, 4 votes
Wow! I had the same problem and this worked like a charm! THANKS A MILLION!
Comments:
Apr 19, 2007
- THANKS A MILLION! I had the same problem and this worked just fine!
Was this helpful?
Yes
No
Solution #14
posted on Apr 08, 2007
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
omg thnk yu it really worked
Solution #15
posted on Mar 13, 2007
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
Oh my Gosh, you guys are awesome! This totally worked for me too!!!
Solution #16
posted on May 25, 2008
Not Helpful)
Whisper91
Rank: Apprentice
Rating: 40%, 1 votes
The following is not a solution:
I tried holding down the power button for 15 to 20 seconds, but this did nothing, except give me the message: "Battery is too low System shutdown." Once the e250 turned off, I plugged it into the USB cable. Unfortunately, instead of going through the process of turning on and connecting to my computer, it merely gave the black and white SanDisk logo screen, dimmed, got white at the top and bottom, went completely white, and then started at the black and white SanDisk logo screen all over again. I began having this problem yesterday after lightly sitting down on it. I would be rather disappointed if that was the cause of the problem, in knowledge of my weight (only 150 lb) and of the total abuse it has had in its year of use in my posession (I bought it new).
One of the first things I did when trying to fix this problem was deassembling, cleaning, and reassembling the device. In the past, I had taken the player apart to clean it, and I always successfully reassembled it.
I'll keep this page bookmarked, just in case some one adds something. (I know, I know, it's been a year since anyone posted anything.)
Comments:
May 25, 2008
- OK, never mind. People have been on this forum/post/whatever more recently than May 2007. Sorry.
Was this helpful?
Yes
No
Solution #17
posted on Nov 20, 2007
Not Helpful)
Guest
Rating: 0%, 0 votes
omg......... thnaks that worked
Solution #18
posted on May 23, 2007
Not Helpful)
Guest
Rating: 0%, 0 votes
Such an easy solution. Thanks.
Solution #19
posted on May 19, 2007
Not Helpful)
Guest
Rating: 0%, 0 votes
Yeah same here worked like a treat!
Solution #20
Not Helpful)
Guest
Rating: 0%, 0 votes
OH MY GOSH.. you are awesome. i just got my sansa today and i just hooked it up to my laptop and it went all blue. i tried this and it really worked. thank you :]
Solution #21
posted on Mar 25, 2007
Not Helpful)
Guest
Rating: 0%, 0 votes
Thank You So Much!!! It Worked!!! OMG!!! Thank You
Solution #22
posted on May 17, 2009
Not Rated)
brncas
Rank: Master
Rating: 75%, 5 votes
Try this link . . . http://www.sansa.com/e250MP3player
To find your best solution.
9
Was this helpful?
Yes
No
Popular Solutions for SanDisk Sansa e250 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa e250 MP3 Player
Do you recommend SanDisk Sansa e250 MP3 Player?
Answer
Answer
Harddisk accidently got erased. Now Windows Media Player won't reconize the unit. HELP!!!
Answer
I can't seem to download an Audiobook. The book shows up on the Audible Manager,but dosen't... (More)
Answer
When I plug my e250r into my computer thru the usb port, on my computer it will show the songs. I... (More)
Answer
as i open my sansa e250 lots of horizontal white lines appearing on my screen and it sucks since i... (More)
Answer
8 Other Users Have The Same Problem - Continued
Comment by hyatt_bling, posted on Mar 03, 2008
ok well i press the power button like im turning it on and the "san disk" screen comes up and it goes blank and just comes up again never turning on completely and the blue ring stays on and it wont connect to the computer when i plug it in
Comment by wsbn, posted on Jan 21, 2008
my mp3 will not turn on
Comment by lhobbs331, posted on Nov 20, 2007
I have held the button down for 15 to 20 seconds, I have talked with Sansa 5 times with no solution, they suggested reformatting and all that did was erase my songs, so now they are telling me to take it apart and give them the information off of the MP3 player. It just taught me a lesson if nothing else, never buy an off brand, and if you do always get the warranty with it.
My next try is to open it call them back again, and they might exchange it.
What is your solution?
Describe your MP3 and Digital Media... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
VIDEOGAME REPAIR SERVICE
(704) 969-1796
we provide professional service with adjustments...
Nationwide Home Theater Install
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
