Error Message H5-01
We have a Sharp MX-2700N. We have error message H5-01. What does the error message mean and how do I fix it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
H5-01 = detecting 5 consecutive POD_1N jams
Check the fusing section for jam paper. (winding, etc.)
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for
input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
To fix this you need to have the fusing unit looked at... could be various problems causing this , from bad paper to bad rollers?
Posted on Nov 24, 2008
The problem is sharp mx 2700n error code h5.01
Posted on Dec 22, 2008
  • 3 Answers
As mentioned you need to check the fuser - you may have to pull it out of the machine - assuming that the harness and sensor have not been damaged - you might have a small chunk of paper that tore off and got lodged in the fuser - or what used to be my favorite, an accordion fold where the one of more sheets of paper gets folded into a small space where it is not tripping a sensor and doesn't bind the fuser from turning but stops every sheet of paper that hits it. Odd things can happen if someone jammed a clear transparency in the system as well - especially when they are not made for laser printers or when accidentally run on duplex mode.
Posted on Oct 11, 2012
What shall do when i encounter "finisher out of service error"
Well you could power off the machine disconnect the finsher phyiscally and electrically and then power on the machine
Jul 17, 2015 | Sharp MX-2700N Color Copier
How do I print to the MX-2700n?
If you are conecting directly you should be using a usb cable and you will need to install print drivers from sharp usa.
Aug 29, 2014 | Sharp MX-2700N Color Copier
What does error code dc on sharp 3100n mean?
image cartridge cyan need to be replaced
Jul 04, 2014 | SHARP MX-3100N
The Sharp MX2700 Colour machine has come up with an error code DK, what does this code refer to.?
This code means the Black Developer powder has reached the end of its life A service call will be needed to replace this for good black prints
Apr 26, 2010 | Sharp MX-2700N Color Copier
When scanning, received error message "selected servers are not found. Consult you network administrator." Never received this error before, and as the administrator, I have not changed any settings.
If your network is set up to DHCP your leases may have expired and your server may have given new IP Addresses to the destinations you want to send to. Check in the settings of the MFP (copier) that the IP address matches what the IP Address (check at the computer as well) on the computer is. When all else fails (including reboot of all) reinstall the software.
Oct 27, 2009 | Sharp MX-2700N Color Copier
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
Error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Dec 01, 2008 | Sharp MX-2700N Color Copier
1,296 people viewed this question
k24674
jasbo
jasbo
