Question about Ricoh Aficio 1035 Copier
Chang the key
Hi
how can i chang the user key in ricoh aficio 1045
everyone know the current key and i want to chang it
thank u
  • graouuh Dec 29, 2008
    Can you tell me more ?
Login as an admin without password and then you'll be able to change it.
Posted on Nov 24, 2008
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
May 21, 2010 | Ricoh Aficio 1045 Black and White Copier
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
May 26, 2009 | Ricoh Aficio 1035 Copier
I have just purchased a 2nd hand Ricoh copier model 2022 and there was no manual. Would you happen to know of a web site I can download the manual. Many Thanks Warren
please download manual from below link :-
http://www.devicemanuals.com/guide/Copier/Ricoh/Ricoh-Copier-Wide-Format-FW770-User%27s-Guide-TXpBNU5EUT.html
or
http://safemanuals.com/user-guide-instructions-owner-manual/RICOH/AFICIO%202022-_E
Thanks
veeru
May 09, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Change the time of the fax on a Ricoh Aficio Super 220
Set date and time;
  • Press User Tools/counter button
  • Press 3 for Fax
The Facsimile User tool main menu appears.
  • Press the number 6 for Key Op. Settings and press the hash key within 3 seconds.
  • Press 18, Date and time or next until it shows.
Select month, date, year or time with arrow buttons,
enter the month with Prev. or Next and enter the correct time and date.
Press OK > PrevMenu > User tools/counter button.
Good luck and please rate me, thanks.
Dec 10, 2008 | Ricoh Aficio 220 Laser Printer
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Nov 05, 2008 | Ricoh Aficio 1035 Copier
How do I put a password on Ricoh Aficio 2051 printer?
go in to user tools, system setting, key operator tools or admin. tools. there you can set up password.
Oct 01, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
Ricoh Aficio 1045 User Key
Someone locked the machine out. You can a hold of who your purchased it from to see if they can give you the key operator code to unlock it.
I can give you the service code to restore it but there are several steps involved in doing that.
If the first option doesn't work, let me know and I'll look up the service program to disable the key codes.
Sep 01, 2008 | Ricoh Aficio 1035 Copier
How do you set a scanned document folder on a ricoh aficio 1045?
do you mean how do you creat a folder to scan your documents into ? if you have document server or scanner buttons on the key pad, then just select scan and mofidy the folder to your choosing.
Thank You,
Mikey
Apr 03, 2008 | Office Equipment & Supplies
Ricoh fax/copy machine
Instructions for 1013F are as follows:
above the blue numeric keys 2/3 there is a button with a small box with 123 in it this takes you in and brings you out of the USER TOOLS MENU.
Press user tool button once...user menu on display
use right arrow key...press3x..Fax Feature..press ok
right arrow2x..ok
again right arrow2x.ok....DATE/TIME on disply .ok
change then ok it once done exit by the 1st button you started with...USER TOOL BUTTON. all the best....
Mar 28, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1035 Copier Logo
231 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
