I have a Mitsubishi WD-6573 that will notturn on. The green status light comes on and blinks for 10,20,30, indef... I have tried to reset it but, nothing. Can you help.
The green LED is blinking because there is fault in the TV you will have to take to a technician to determine the cause.
SUPER8
Thank you for your answer but, the thing is... I already know that. What I was looking for is this is a common problem...or it is a mainboard change...or bad power supply...or a certain needed component of a particular board. Thank you for your response, though.
when we turn on the tv or hit the reset the timer light blinks on and off then the tv just shuts itself down. when we start the tv we hear a crackling noise like the speaker is broken then we hear static then we hear the crackle again and the tv shuts down.
I am having the same problem. The crackling noise is coming from the vent just to the right of the bulb panel. You can actually see the short occurring. It will power on, you hear the fan, then the crackling noise (which you can see if you look at that vent while powering on) then the fan slows down and it powers off. There is a short, but to what is shorting...I have no answer.
My t.v was crackling to.It's the main ballast board.encompass.com has for $296 with $100 core.Just dissasemble all screws on back to acces lamp and board.Board comes out pretty easy.Alot of discussion/blog forums are saying bad ballastboards,soders,and lamps.
