Blackberry 7130e. It is showing that it has a signal but i cannot recieve or make any phone calls or texts. It has an arrow flashing at the top by the signal like its sending somthing constantly...how do i...
This problem happens on pretty much any computer-related device.
Something happens and you can send
anything. It’s annoying, but there are actually two ways to fix it. You
can perform a soft reset, which is done by pressing the ALT + CAP +
DELETE keys on your handheld at the same time. If this doesn’t work,
perform a hard reset. This is done by finding the RESET button at the
back of the handheld. Sometimes, this button might be near the bottom,
under the battery cover. Press the RESET button using a pin or paper
clip. With either method, you shouldn’t lose any data.
Perhaps, is you did not see the reset button,you can also do the hard reset this way, in the process of powering your phone, pull out the battery straight before it finish loading, this helps fix abnormality on the blackberry phone.
Take care.
