Question about Sony PlayStation® 3 (60 GB) Console
My ps3 system recently stopped reading any discs
My ps3 console stopped reading discs after inserting into the drive. the discs just stays in the drive does not load please suggest a solution
  • 4 more comments
  • shawn f Nov 25, 2008
    my ps3 does not load any discs. i need help!
  • sadie120979 Nov 28, 2008
    I recently replaced my blueray laser and i've put it all back together but now it won't take any disc's in...............what do i do?
  • chris_lou5
    chris_lou5 Jan 06, 2009
    just bought Fall Out 3 and it frozed, I press the off button in the front of the PS3, still not turning off so i turn the switch off in the back. Turn it back on and nothing reads.. : ( ! now im going crazy !
  • Anonymous Jan 20, 2009
    My 60 gb PS3 has stopped reading any dicks I insert. What shall I do?
  • terrence473 Jan 21, 2009
    After trying to play a PS2 disc in my PS3 it stopped working. Is it broken or is there a setting on it that would have changed when it tried to read the PS2 disc.
    Please help, very frustratingnot being abl to play.
  • djv555 Jan 22, 2009
    I have the same problem as well
    The only thing I found out was to return it to
    SONY for repair for $159.00
My ps3 will not read any disc, except DVDs
Posted on Jan 21, 2009
  • terrence barrett Jan 21, 2009
    Is it easy to install and how much does a blue ray lense cost
I have got the same problem, you can either get a new blue ray lens and fit it yourself or give sony a ring and they will change your console for you.
Posted on Dec 09, 2008
Unable to read the disc
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
Take care.
May 30, 2010 | Nintendo Wii Console
Wheni put a disc in the ps3 it does not load up so i cant play on games my software version is 3.21
hi,
May 28, 2010 | Sony Playstation 3 (PS3) Console
Ps3 not reading disc..Please help
Do you see the little clock like icon in the top right corner of the screen when you first insert a disc the loading disc icon? if so then it could either just be the drive itself or a software issue in which case you can try a few things before replaceing the drive.
First just reset to factory default settings under system settings.
P.S. i assume its not reading any kind of disc if it isnt reading anything also double check to make sure the disc you are using are still good and not just really dirty or scratched. GIve us more info and what disc your trying to check so we can further help you out.
Justin
Apr 29, 2010 | Sony Playstation 3 (PS3) Console
PS3 not reading discs.
Hey man, you can try this....
1. download and install a psn game or game demo
2. put in the disc of the game or video you want to play or watch
3. load the psn game or demo as if you were going to play it
4. quit the demo as soon as you get to the start menu of it
5. go and play or watch the game or video you wanted to, sucka, cause it works now!!!
I hope this works for you, and if it does, spread the word!
Feb 21, 2010 | Sony PlayStation® 3 (80GB) Console
PS3 BluRay Drive Issue
dont change the drive change the laser dhe drives are coded to each ps3 if that dosent work just change the hard drive whit the one that works
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
PS3 stopped reading PS3 games
This is most likely do to a previous freeze up while on the PS3. All you have to do is to first disconnect all of the plugs and wires. Then you put them back in and turn on the PS3. It should read your PS3 game discs.
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
My PS3 has stopped reading discs. Whenever I put
Sounds like the HDD is in need of replacement. This is common with aging PS3's.
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
Ps3 disc drive not working.
You've done everything I would have done honestly. Take a can of air and blow it into the drive to make sure dirt or dust isn't on the laser which could affect if it sees discs or not.
The better thing to try if you are good at opening up your ps3 and then removing your drive and opening that is to take a damp q-tip with a bit of glass cleaner and clean your laser in the drive gently. Then put the drive back together and hook the cables back up to the ps3. You can leave the cover to the ps3 off for this step. Turn on the ps3 and try different blu-ray, dvd's, music cd's, game discs, etc. If it still doesn't read any of them then either the laser or the drive i bad. If it reads some discs and not others then its a weak laser and the laser would need to be replaced.
If you have to replace the laser or the drive, you can do a search on Ebay and usually find them fairly cheap.
Hope this helps and let me know if I can be of further assistance.
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
PS3 is The amazing device by sony but it has some common problems like unreadable disc, disc error etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
252 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
