Here in this post I explain about a specific problem faced by Toshiba eStudio printer users. Toshiba eStudio series is high speed printer and mainly used in corporate offices. One day when you work all of a sudden you receive an error message from the printer and it shows C44 and now you can't print anymore. Frustrating isn't it?
Little bit facts about the C44 error, C44 simply means that the count of printer has gone above the limit and it needs service. But in most cases its false positive, means many reasons can bring up the issue. Some of them include over heat of printer parts, issue in settings, or any particular component failure but above all it occurs for some unknown reasons also and that's why you can use this to rectify the issue. The advantage of doing this is that if the issue do not solve up after doing this you can call you service engineers but if it gets solved it can save your money for calling the service engineers. Solution:
Switch off the printer first.
Now Power the Printer by pressing 0 and 8 keys (keep pressing).
Then a test mode comes up.
Now Type 400.
Press START (!)(You will get a counter and now you need to reset this).
Type 0.
Press Enter(start)
Switch off the Printer now and restart and check again with first steps till typing 0 (You need not type 0).
Now switch off the printer and on it normally.
You should see printer working normally
This fix is applicable to all Toshiba eStudio printers.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
You should apply to service Toshiba. The Possible faults in lamp of the heating, thermistor, contact of the elements of fuzer or in signal of the controller of the direct current.
C41
Fuser thermistor, or no heat
C43
Fuser thermistor problem or other fuser problem, after machine goes into ready
C44
Heater problem
When the message call for service is displayed press the C key and the 8 key at the same time an alpha numeric code will appear eg: C47 etc Post the error code and I'll tell you what it means
