C3000 Hello Inky, This problem is not yet solved: The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem. Do you have good tips for this? Thanks, Marko
  • MarkoP Nov 27, 2008
    We have not been able to try this yet but we will in a week. I´ll rate this solution then.
    Marko
  • 691 Answers
Hi Marko, the issue has been sorted fully by a fairly simple update to the firmware. There is a complete solution available from the address below. I spent ages messing around trying to find the correct fix for the firmware. I came across the solution below and found it 100% effective for the machines I have used it on.
http://www.tradebit.com/filedetail.php/4942713-epson-c3000-c4100-jam-at-fuser-rescue
It's not a free fix, but it is damn cheap, and I can vouch for the fact that it works.
Posted on Nov 24, 2008
Need help finding & solving high pitch whine at mid to high speeds
It sounds like a Bearing is worn in one of the wheels or in the Drive-shaft. Get a mechanic to check it out
Jan 15, 2014 | 1994 Ford Crown Victoria
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
Hi. Epson C3000 aculaser. It is ghosting on only on black at a pitch of +/-62mm and also printing horizontal black smudges across both side of the paper at a pitch of +/- 25mm. I have totally cleaned the...
Hi Colin.
I just have had the same problem with my Aculaser C4200.
I may have found a way to solve you problem.
Just print 10 blank (without anything), and after that i took all toner's, the fuser etc. and put it back again. Printed 10 more blank pages, and printed over 200 pages with lot of tekst and colour (think that 50 pages could do it).
After 2 days everything is still ok for me.
Sep 30, 2010 | Epson AcuLaser C3000 Printer
My Braun 7570 has suddenly stopped working, but there is a high pitched whine when I switch it on.
This sounds like a battery problem. The likely remedy is to replace them. You will find batteries for your shaver at shaveroutlet.com
Jan 17, 2010 | Braun Syncro 7570 Electric Shaver
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Part Number for RICOH Aficio MP C3000 Fuser Unit
Part number is: B237 4053 (North America)
B237 4054 (Europe)
I Expect this will be very expensive as it is not designed to be replaced as an entire assembly, but rather repaired as needed.
Feb 23, 2009 | Ricoh Aficio AP2000 Laser Printer
Papaer will not feed
High ITConsult And MarkoP
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Phaser 6250
That problem is the registration clutch.
You have to order the registration assembly to get the clutch. It is located on assembly with the black and stainless steel roller, you have to pop out the imaging unit to see it.
But that WILL fix your problem. They changed the style of clutch also. It is more reliable now.
May 01, 2008 | Xerox Phaser 6250DP Laser Printer
HP LaserJet 1100
Does it only whine when it paper is passing through it? Does it whine before the paper is fed in and after it's ejected? If so, could possible be the fuser unit. If it only whines when paper is passing through, it may be the paper passing between a worn-out feed roller and separator pad, which are high-mortality items on this model. Can you supply any more details?
May 10, 2007 | HP LaserJet 1100 Printer
80 people viewed this question
k24674
jasbo
jasbo
