Question about Samtron MONO TTL 13 Monitor
Sync out Of range
I'm using a samtron monitor for the past 5years...since i bought a new cpu..the computer constantly shows a 'sync out of range error'. but if i continuously resart my computer.. it comes on...please help
i use a samtron 56v
windows xp
my current settings are 37.9khz 60 hz PP (whatever that is!)
Out of rang
Posted on Dec 24, 2009
  • 390 Answers
You need to get the monitor back into a range it can use and the best way is to go into SAFE mode on the pc put it back into 640X 480 and at 60 hz refresh rate. 37.9khz is way too high for the monitor!
It is best in the 60hz to 80 hz (if it can go that high!) start at 60 to begin with and it will work.
Good Luck!
Rich Lilja
Posted on Nov 26, 2008
My monitor not showing shoing red color ,
this mostly problem with the display connector refix it properly with your cpu and check of its not working go for service ....
Nov 02, 2009 | SAMTRON 55V 15" CRT Monitor
Sync out of range
If using windows, boot to safe mode, and make sure your resolution is low enough for your monitor to handle.
Check your cables to make sure there are no broken pins.
Sep 16, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
Analog Monitor problem
The problem in your monitor is SRGB
Use 3 simple steps to rectify this problem
1. Connect your monitor to another CPU
2. Change The Resolution to 800x600 32/24bit
(After 2 Miniuts SRGB will Reset)
3. After 5 Miniuts change the monitor to your CPU
Thank U
Apr 06, 2008 | Computers & Internet
Samtron 15" CRT monitor gone dark but readable!
Go to a computer fair and get a flat screen monitor for around $195 dollars. Why even keep this anicent artifact in todays new screens?
Feb 28, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor
HI all,
The problem im facing is, im using a Samsung samtrong 56V monitor, there is horizontal line appearing in the both ends of the monitor screen which gives a mirroring effect. ( for ex: if ya move the cursor on that it will show multiples of cursors displayed in that line only.)
Please suggest me a method to solve this issue. are there any patch avail for this if so please send a link to download.
thanks a lot
Jan 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Monitor color has been changed to yellowish.
There are three Cathod Ray guns responsible for the millions of
colors.All colors are produced by mixing the three basic colors namely
Red Green and Blue (RGB) at suitable proportion. If any one of the
three guns fail firing then we get improper colors.
(1) Simply tap on the monitor and see the result.(Keep the monitor on during this trial.)
(2) Disconnect the Monitor.and Slap it at the back by keeping it on a pillow with the screen facing down - it will resolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contraction.
(3) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed) -
(4)tighten the screws at the backside of the CPU
Best of luck
Sep 14, 2007 | Samtron 76df 17" CRT Monitor
Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
333 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
