Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Arctica - Frig Freezing Food
Model: PSS25SGNA BS - The frig set to 0 and maintains temp fine. Frig side set to 37, but says much cooler (16 - 25) and is freezing food. I believe it's also froze the water filter cutting off wather for the ice maker (runs, but no water thus no cubes), and the door (no water). There appears to be no blocks in the upper and lower ports to the freezer. Main board replaced with no change. Thanks for your help!!
  • 2 more comments
  • aled969 Dec 05, 2008
    PSS25SGNA GE Profile Side by Side. Experiencing same exact problem.
    Refrigerator has been dropping temperature for about 2 months. Freezing veggies. Also, water line is not dispensing water now.
  • kc7hex Feb 22, 2009
    PSS25SGNABS Model with the same problem. Frig side set for the recommended 37 degrees and it always freezes the food (below 30 degrees). Water also not dispensing. Swap out the main control board and the water synoid and the same problem exists. Need assistance.
  • Anonymous Mar 07, 2009
    PSS25SGNA with the same problem. Refrigerator won't hold temperature, no water from door, but the ice maker still works, We have unplugged it today and cleaning inside and out - a friend recommended letting everything thaw, maybe something is stuck? Seems illogical and a long shot, but at this point need something and can't afford a repairman, much less replacement right now.....
  • kruty9 May 14, 2009
    My freezer temp set to 0 and stays fine according to temp readout. My fresh food section temp set to 37 but readout shows 28-32 and food is getting frozen. I tried to compensate by rasing temp settings to 5 in freezer and 44 in frash food section. This helped and the gage readings are 5 in freezer and 33-34 in frash section. My frige is 6 years old. The problem has started 2 weeks ago. Can someone help?
    Problem Solver:
  • 15 Answers
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Posted on Feb 09, 2010
My food in the refigerator is freezing on the top shelf and bottom. I have turned down the control from 5 to 3 and it is still happening. Usually the milk and bag salads.
Posted on Mar 30, 2011
Freezing food in frig. , not making ice .
Freezing food in the fridge also freezes the water line for the ice maker.
You have a thermostat problem. Get a new thermostat fitted.
Mar 31, 2011 | GE Profile¿ Arctica® Energy...
Food in the frig has been freezing even when the freezer is set to 3 and the frig is set to2 (mod. pss25mgmb) the unit is only about 6 yrs old
could be drain holes blocked or both temp sensors gone at same time ?? hardly.also have you tried a full manual defrost (no hot water) sometimes works for me
Feb 07, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Frig won't hold set temp keeps freezing things.
Thermostat is defective.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
2,304 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
