Question about Lexmark X644e All-In-One Laser Printer
Paper feed problem on Epson C87
A sticker sheet was stuck on the paper feed roller.
Having cleaned that the cartridge and the paper feed light indicators keep blinking continuously and the paper does no feed.
I was advised by an epson service outlet here to change the black cartridge but it didnt work.
Any suggestions?
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi there
    Can you clarify your problem. There is only one paper feed light indicator so your "paper feed light indicators keep blinking continuously" is confusing. Do you mean the ink and paper feed lights (the red ones) both blink? If so, it means that something is jamming the paper feed. To be sure that all is clear in the paper feed route might need the printer top cover to be removed. Come back with a new comment if you want help with this (really easy to do if you know what to do, incredibly frustrating and difficult if you don't!)
  • 353 Answers
In view of vk_malik's lack of interest in this problem, I think we may declare it "solved by poster"
Posted on Mar 22, 2009
Paper fee picks multiple pages. Normal paper. Have tried all the different platen gaps. Help!
Epson printers use a set of rubber rollers to pick up the paper. Some paper can leave a slick deposit on the rollers, causing mis-feed. I spray some cardstock lightly with alcohol, and run it through several times (use the paper feed button) to clean that off.
Also, check the paper itself, if the sheets stick together, "fan" them before putting them in the printer.
Feb 15, 2016 | Epson Stylus Pro 3880 Inkjet Large Format...
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    E2 error code on Xerox work centre xd series 120f copier
    e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
    Nov 05, 2009 | Xerox Office Equipment & Supplies
    Will not feed paper of any size. No jams ever.
    clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
    Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
    Paper not feeding through getting stuck halfway
    One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle white roller. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
    To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
    Next, try this printer self-test by following the steps given below:
    1. Power the printer off.
    2. Press and hold the "Paper Feed" button.
    3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
    4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
    5. Power the printer off, as this test is continuous.
    The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
    If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
    If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
    Apr 10, 2009 | Lexmark X1270 All-In-One InkJet Printer
    Epson CX7800 3 in one printer feeds mulltiple sheets.
    This is usually caused by a dirty or dented feed roller.
    The feed roller is the black wheel that has s flat side to it above the paper tray. Try using a Q-tip and some rubbing alcohol to clean it. Then give it another whirl.
    As with the ink on the paper. This is usually caused by leaky printheads. Epson printers are notorious for having the printheads die on them, but usually from the ink drying out. Check and see if the bottom of the printhead can be reached and cleaned by Q-tip or cotton swab. Give it a good cleaning using rubbing alcohol. Don't go over board as the alcohol will dilute the ink.
    Mar 28, 2009 | Epson Stylus CX7800 All-In-One InkJet...
    R360 wont feed paper in to printer
    You need to clean the pinch roller at the back of the printer using a cleaning sheet. These come with packs of Epson Photo Paper and are slightly tacky which removes the paper dust and grime from the pinch roller.
    Mar 12, 2009 | Epson Office Equipment & Supplies
    Not feeding
    Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
    Also check the feeder tray.. to grab paper one by one by printer.. Manually
    Take all updates for printer and OS.
    Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    Lexmark X644e All-In-One Laser Printer Logo
    88 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
