Question about Mitsubishi WS-55907 55" Rear Projection Television
3d imaging won't go away or adjust
The set is constantly in 3D mode and we can't seem to reset it. We don't have the original remote for it either. Can you help?
    Genius:
  • 1,694 Answers
Sounds like convergence issue--Replace Stk IC's and reset alignment.
Posted on Oct 04, 2007
HOW DO I PROGRAM MY XFINITY COMCAST REMOTE
Check here for a list of manufacturer codes for your specific remote: Comcast Cable Remote Support
Check here for a video of how to get into programming mode: Program Your Comcast Remote
Comcast's remote page seems to be broken right now, but may work in the future: Comcast Remote Codes Program Your Comcast Remote Control
Please post back if these don't help!
Dec 23, 2014 | Samsung UN46D8000 46" 1080p 240Hz LED 3D...
How do I adjust the convergence on an RCA HD52w59?
How old is the tv? all the new one are done through the remote by entering service mode.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Sep 08, 2014 | RCA Televison & Video
Why does my projector display a double image?
You may have turned on a 3D (side by side) mode.
Have a look at your remote, press the 3D button (you may have to press it several times) to cycle through the virtual 3D modes.
Once you see "3D off", the double image should go away.
If you want to use 3D again, simply cycle through the modes to go back to where you want to be.
Jul 25, 2014 | Sony VPL-HW30AES 3D 1080p Home Theater...
How can I off the 3d effect in my Samsung led UN40D5500
When I looked at the specifications for the UN40D5500, that TV doesn't have a 3D video option. It does allow for 3D audio on the digital audio signal. The UN40D5550 has 3D video. To toggle through the 3D settings, press Menu on the remote (in the center of the row above the arrow toggles) and use the down arrow to go to the Picture sub-menu. Press Enter then with the arrows go to 3D and press Enter. Under 3D Mode, you can toggle with the left and right arrows through Off, 3D, 2D upconverted to 3D, side by side images or two images stacked one over the other. Press Enter to save the setting. Press Menu several times to exit the menu system.
If you do have the UN40D5500 and are trying to disable the 3D audio, press Menu and go to the Audio sub-menu. Then look under the digital audio options (SPDIF).
For other manuals for Samsung devices, go to http://www.samsung.com/us/support/downloads .
I hope this helps.
Oct 21, 2013 | Samsung "UN40D5500 40"" LED TV "
I cannot turn on 3d mode on my lg projector pa70g cause it doesnot see this mode. And when i click 3d button on the remote it doesn't change the picture. Help me please!
you need to be connected to a 3d source when you try and switch and it must be playing 3d media before the projector would even try and im sure you know you need to be connected via hdmi for this to work, so grab a 3d dvd player and a 3d capable hdmi cable and a 3d dvd and then try it--Good Luck.
Jan 28, 2013 | Televison & Video
My 47 inch vizio 3dtv has issues with the 3d. There are two images and neither are in 3d. The glasses don't work.
You have to put the TV into 3D mode to view it by pressing the 3D button on the remote. Before you press that button, look at the screen... if you see two images side by side, then you would choose SBS... if the images are one on top of the other, then it is the over/under mode, or with Vizio,Top/Bottom option which is the "TB" icon. Once you have chosen this, the screen will inform you to put on your 3D Glasses.
Aug 15, 2012 | Televison & Video
I SEE DOUBLE IMAGES/LIKE 3D HOW DO I SOLVE WITHOUT REMOTE?.OR HOW DO I RESET THE TELEVISION TO DEFAULT SETTING
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 22, 2011 | Sony KP-53HS30 53" Rear Projection...
Double image and 3d color
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Jan 17, 2010 | Sony KP-43T90 43" Rear Projection...
Open Questions:
Mitsubishi WS-55907 55" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
