Question about Microsoft Office 2003 Basic Edition English (s55-00066) for PC
Excel formula for example i am doing a report using excel. I have no. 5 in sheet1 cell a2 and nos. 2,45,6,76,88 in b2,if i click sheet 2 the output must be sheet 2 cell a2 b2 5 52 5 545 5 56 5 576 5 588
  • jomsdapa Nov 25, 2008
    ill try the solution later,thanks for the help..
    Problem Solver:
  • 7 Answers
You can do that using the formula CONCATENATE, solving your report.
in C2 you could write: =CONCATENATE(A2,B2)
in C3 you could write: =CONCATENATE(A3,B3)
in C4 you could write: =CONCATENATE(A4,B4)
in C5 you could write: =CONCATENATE(A5,B5)
Posted on Nov 24, 2008
I calculated percentage on excel using a formula but still it shows #value?. what do i have do to fix this? please help.
Right Click on cell with mouse and select format cells
then select number . If formula was for example percentage of cell a2 calculated from b2 calculated in c2 then in c2 you put =a2/b2
Then you can use percentage in the number format
or you can go =(a2/b2)*100
Also make the cell width more if a problem.
https://www.youtube.com/watch?v=UlD6vUKx2KE
Apr 08, 2017 | Excel Computers & Internet
I want to make an excel record a data in a different sheet when i feed the name of a student in a sheet in the same cell
Without more specifics as to what you want to do here is how to link a cell on sheet 2 to sheet 1.
Example:
If you want to sheet2 cell A2 to be the same as sheet1 cell C4 you would simply input "=sheet1.C4" into sheet2 cell A2 (without quotes). You can reference any cell on any sheet to another.
Hope this helps!
Mar 24, 2009 | Microsoft Computers & Internet
How to use vlookup in openoffice using different sheets
=VLOOKUP(A2;Sheet1.$A$3:D27;2;0)
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
Feb 11, 2009 | Microsoft Excel for PC
VLOOKUP FORMULA PROBLEM
VLOOKUP(A1,Sheet2A2:B20,2,FALSE)
The assumption here is A1 in Sheet 1 is the cell you want to reference, This cell can be pasted - Any problems let me know.
Jan 21, 2009 | Microsoft Excel for PC
Excel formula,
the basic idea of an if statement is just that if this then that. Thus a formula could look as simple as =IF(A2=1,25,IF(A2=2,10))
Jan 10, 2009 | Computers & Internet
Excel formulas
hello
yes it is.
example
sheet1
A1 (50)
A2 (50)
sheet2
(A1)=
"=Sheet1!A2+Sheet1!A1" <-this is the actually code in sheet2 column A1
ok let me explain
in A1 and A2 in sheet1 you got 50 and 50 like numbers.
in A1 on Sheet2 you have = sheet1 a1 + sheet1 a2.
did you get it?
dont know else how I should explain it...
good luck
Oct 09, 2008 | Microsoft Excel for PC
Excel formula
I'm assuming you'd like to assign a numerical value to cardinal references (1st, 2nd, 3rd, 4th, etc.).
Best way to do this is to create a quick lookup table on a separate sheet of the same .xls document. Down at the bottom of the page, click on Sheet2 and create a quick table where column A has 1st, 2nd, 3rd, etc. and column B has your values.
Now click back to Sheet1 where your data is and in A2 put this formula:
=VLookup(A1, Sheet2!$A$1:$B$x, 2, FALSE)
Note: replace the lower case x in the formula above with the number of the last row of data in your lookup table on Sheet2.
You can copy and paste this formula down the column to calculate your other values.
Hope that helps!
Terry
Aug 30, 2008 | Microsoft Excel for PC
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
Help with simple excel calculations
Hello.
For cell B1 you can use this (without the quotes) "=A1"
Then for cell A2 and down you don't need a formula, but for B2 you can use this formula. "=(B1+A2)" Then click on that cell and drag the mouse down for as many cells as you want this formula to include and press Control and F keys to fill the formula down the column.
For your second formula, you would type 100 into D1 and in D2 you would use the formula "=D1-E1" (again, no quotes).
Feel free to let me know if you need any more clarification or if I missed something!
Jun 10, 2008 | Microsoft Excel for PC
Excel formula
CHOSE THE PERTICULAR CELL WHERE THE SUM IS GOING TO BE DISPLAYED AND HYPERLINK IT IT WITH SHEET 2
Apr 12, 2008 | Microsoft Excel for PC
Microsoft Office 2003 Basic Edition English (s55-00066) for PC Logo
193 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
