Question about Belkin 802.11g Wireless Desktop Network Card [ F5D7000 Wireless ] (109061)
Default ip address
I have reseted my wireless connection , now i can not ping or get into it , i do not know the default ip address.
please help me
  • moselebaruti Nov 24, 2008
    i have reseted my wireless connection , now i can not ping or get into it , i do not know the default ip address.
    please help me
  • 53 Answers
Do you know what router you have?
Posted on Nov 24, 2008
  • Ismaldo Sosa
    Ismaldo Sosa Nov 24, 2008
    go to whatsmyip.org or go into command prompt and type ipconfig /all
Can't ping internal page
It may be that the WAP was set-up to use a different subnet from the default.
Check the IP address that is assigned to the computer that is connected to the router and substitute the first 3 octets (192.168.10 is the default) with what your computer reports. So, if your computer has an IP address of 192.168.22.32, then use 192.168.22.100 instead.
If that doesn't work, you will probably have to do a factory reset on the device to get it to use the default address.
Downloads for this device are available here: (click here)
Feb 05, 2012 | Trendnet TEW-650AP Wireless Access Point...
Tip
Before you start configuring the WRE54G you need to consider the following...
Before you start configuring the WRE54G you need to consider the following factors:
1. Make sure that there are no wireless security enabled on the router like WEP and wireless MAC filtering. If you have them enabled try to disable them first. Check if there is a wireless computer that is currently working on your network.
2. Make sure that the SSID broadcast is enabled.
3. Then Hit the Automatic Configuration button on the WRE54G for about 3-5 secs.
The wireless computer should be connected to the SSID of the Range expander.
The range expander doesn’t have any DHCP server. The IP address that will be assigned to the computer will be 0.0.0.0 or the Auto-configuration IP 169.254.xxx.xxx.
Assign a static IP address on the wireless card. IP address should be 192.168.1.5, Subnet Mask 255.255.255.0, Default gateway 192.168.1.1
To assign static IP address on your machine you follow the steps below:
Windows 9 xs and ME:
Go to Start > Settings > Control Panel > Network > Highlight the TCP/IP of the Wireless LAN card you’re using > Properties
Under IP Address TAB:
Specify an IP address: 192.168.1.5
Subnet Mask: 255.255.255.0
Click the GATEWAY TAB:
Under New Gateway: Enter 192.168.1.1 then click on Add.
Then Hit Ok All the way out… hit yes if it’ll ask you to restart
Windows XP and 2000
Go to Start > Control Panel > Network Connections > Right Click Local Area Network Connection that you are using > Properties > Internet Protocol TCP/IP > Properties > Use the following IP address:
IP Address: 192.168.1.5
Default Gateway: 192.168.1.1
Then click ok all the way out.
Try to ping the Range expander. Go to start and then run type CMD for Win XP/2000, COMMAND for Win ME and below. On the black screen that will pop-up type PING 192.168.1.240 (Default IP address of the Range expander.
If the ping test was successful then you can access the setup page of the Range expander. If not, try to reset the Range expander for 10 seconds and then power cycle it.
To reset the range expander, follow the steps below:
Hold down the reset button for 10 seconds then unplug power while holding down reset...plug it back in after 5 seconds then wait for 10 more seconds before releasing the reset button.
To access the setup page of the expander, Open your Internet Explorer and please go to http://192.168.1.240
If will prompt a username and password box, leave the username blank password is admin.
On the setup screen of the expander, you can set the same exact settings on your router. SSID, Channel, WEP settings should be the same on the router and you need to specify the WLAN MAC Address of your router to the space provided for the WLAN MAC address on the setup page of the Range Expander.
Once you applied the settings, the lights on the expander should be both blue.
You can now set your IP address back to obtain an IP automatically and Obtain DNS address automatically.
Range expander should be working after performing the troubleshooting steps above.
If you have an Ethernet port on the WRE54G, try to connect the range expander directly to your computer with static IP address then ping the WRE54G. Make sure that you are not running any firewall and Internet security in your computer. If you were able to ping the 192.168.1.240 try to access it through the Internet Explorer and configure it from the there. Follow the steps that I gave to you to configure the wireless settings of the range expander.
Make sure that you have checked all the wireless security settings on your router. Make sure that you have those disabled. Try to set static IP address in your computer and try to ping the 192.168.1.240 and see if you can get a reply.
To set static IP follow the steps below:
Windows 9x and ME:
Specify an IP address: 192.168.1.10
Windows XP and 2000
IP Address: 192.168.1.10
Then Hit Ok All the way out.
on Mar 08, 2010 | Computers & Internet
Tip
Configuring WRE54G to a wireless router
Windows XP and 2000
Windows 9x and ME:
Windows XP and 2000
on Feb 07, 2010 | Linksys Wireless-G Range Expander (WRE54G)
I have DAP-1160 wireless G access point. My pc won't rekognize it. it worked befor reseting, after that the STATUS led does not blink.Not even when it's connected to the pc. What is the problem?...
I had the same problem with a DLINK DAP-1160, it did not seem to reset and I could not connect, nor PING it. It turned out that the box WAS resetting, and although the default IP address 192.168.0.50 and subnet 255.255.255.0 was being set, my computer was assigning itself up a private IP address and subnet 255.255.0.0. In the manual, it does say that you must be on the same subnet, so I changed my alternate IP address for my ethernet to be static and set the subnet to 255.255.255.0 and everything sprung in to life.
To summarise: make sure the computer you are using to configure the DAP-1160 has its subnet to 255.255.255.0.
May 08, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
My netwrok consists of one laptop and one PC. the lap top can connect to the internet perfectly, the PC advises that it can connect to the access point, but not the internet
If you are trying to connect wirelessly to PC than check the ip address after it says connected. If the ip address is correct than try to ping the default gateway(To check the default gateway, Click Start-> Run-> ipconfig. You will get the default gateway), 4.2.2.2 and yahoo.com.
Let me know your findings.
**If this works please rate else let me know in case of further help.**
Jun 26, 2010 | Linksys Wireless-G WRT54GS Router...
I can't log in to configure my router. I tried loging in using 192.168.1.1 but its not working an I don't know why. Help please
You may need to double check if the router is giving the correct IP address. You can this by doing the following:
1. Go to Control Panel.
2. Got to Network Connections
3. Right click on the the connection that you are using to connect to the router, wired or wireless. Then go to Status.
4. Go to the Support tab. Check the IP address and the Default Gateway, it's the Default Gateway that will tell what is the correct router IP address.
After you verify the correct IP address, you test if your computer is still communicating with the router. To do this, do the following:
1. Click Start go to Run and type "cmd" and then hit return.
2. In the command prompt, type this command "ping 192.168.1.1" or ping whatever IP address you will see in the support tab for Default Gateway.
You should get four replies if your computer is communicating with the router. If you not make sure that you disable the firewall/s in your computer. You can also use a different computer.
Jun 19, 2010 | Computers & Internet
If a change in my firewall is preventing netgear router, i do i fix?
First, make sure the cables are properly connected, if using xDSL modem, it must be connected to the WAN port, the pc on the ethernet ports (any of the 4 ports available).
Second, check your current IP Address (default 192.168.1.x), then ping from your pc the ip address of the router (default 192.168.1.1). If OK, then your LAN connection works fine.
Third, ping any internet site, i.e. ping www.yahoo.com. if a reply response is received, your internet connection is now working.
If not, reset the router then do the initial set up from the router web page. Go to IE or mozilla browser, type http://192.168.1.1 (default ip add of router), the password or username is admin (default - refer to your manual). If already inside the page, go to the setup folder then proceed to configure the router. After all the configuration, check your internet connection, go to any web site.
Sep 15, 2009 | NetGear WGR614 Wireless Router
I have a Linksys Wireless G WRT54G Router version 5 and I lost my setup disk and cannot access the internal web based setup and Iv done everything Iv read to do and now its not even showing up as a...
Hi there. No need to run the setup CD. Check the IP address first to see if the computer is communicating with the router. Go to command prompt (if XP, simply click start then go to run and type in CMD and hit ok. A black screen will pop up. Type in IPCONFIG then enter. Check the IP address and default gateway (by default, the router's IP is 192.168.1.1 which will show as the default gateway). Launch internet explorer and type in the default gateway on the address bar. (No www). If you cant pull out the page. Go back to the black screen (START>RUN>CMD) and type in ping (default gateway) ex. ping 192.168.1.1 there is a space between ping and the default gateway. If you got 4 replies you should be able to access the router's page if not, reset the router by pressing and holding the reset button of the router (usually it is the red hole at the back of the router along with the ethernet ports) for 30 seconds. After 30 sec, power off the router (unplug at the back)never release the reset button and wait another 30 sec then plug the power back in and wait another 30 sec before releasing the reset button. You should be able to access the page then. Go back to the black screen (START>RUN>CMD) then do again a ping test. type in again ping and then the default gateway. (ex. ping 192.168.1.1). You should be able to access the setup page now.
Sep 08, 2009 | Linksys Wireless-G WRT54G Router
Cannot "ping" 192.168.1.1 (default gateway)
1) yes, referring to the router's IP address.
2) I determined the IP addresses of all my computers and tried to "ping" them but could not "ping" any of them. I can "ping" the IP address of the computer I am working from but I don't think that helps in TS this situation.
3) I'm wondering if my router is fully set up correctly. Do each of the computers have to be "saved" in the router's settings?
Jan 11, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
Belkin 802.11g Wireless Desktop Network Card [ F5D7000 Wireless ] (109061) Logo
35 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
