Question about Bosch 24 in. SHU53 Built-in Dishwasher
How do I replace the heating element for a Bosch SHU53 dishwasher
My Bosch dishwasher SHU5316UC/U12, installed 3/4/03, had the heating water element go out. I ordered another one from Bosch, but it did not come with installation instructions. The only installation instructions the company sent me were how to install the dishwasher under the counter. I took the dishwasher out, turned it over, looked for an obvious kick plate removal or something. But not wanting to break anything, do you have any hints on how to remove and install a heater in this unit?
  • Jeff Miner
    Jeff Miner Feb 03, 2009
    Thanks daddy1264,
    I took the control board out and took it to a friend who fixes electronics, he found one bad soldering joint and three that were going bad. He scraped off the green plastic covering to reveal the copper, soldered the points and it works. The heater was not the problem. Thanks for the tip. Now I have to try to send back the unused heater. Bosch already refused to take it back after 10 days. Someone suggested I take it off my credit card.
  • hap5
    hap5 Dec 04, 2012
    Where is the control board located? I have model #SHU33A02UC/22
  • 76 Answers
Are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes can resolder that
Posted on Dec 30, 2008
Bosch shu5316uc filling fault
Test the water inlet electro valves.
May 26, 2017 | Bosch SHU5316UC Dishwasher
Does not wash the top rack properly
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Nov 07, 2010 | Bosch SHU5316UC Dishwasher
Will not heat up
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
Dishwasher2_bing.gif Maintenance
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 10, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a SHU5316UC dishwasher. How to cancel and
hold down scrub wash and the delicare or the 2nd one past scrub wash, for 3 seconds.
May 05, 2010 | Bosch SHU5316UC Dishwasher
Bosch Dishwasher Model SHU5316UC-06 -- what does error code 2H mean?
2H is not exactly an "error code", but it does indicate a problem. It means that the machine exceded its wash time by more than 2 hours. This is usualy caused by a failure of the heater, most often caused by a failure of the controll. Remove the control from the door, remove the plastic housing from the control, and check for a bad solder joint on the heater relay.
If you find a bad solder joint, REPLACE the controll.
Or call a qualified service person.
NOTE: The SHU53A dish washer with serial numbers from FD8205 to FD8507 are included in a factory recall. If your dishwasher is one of these contact BSH @ 1-800-586-9226 24/7.
Mar 28, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Even after ensuring that really hot water is coming from the faucet and placing the unit on the Delicate/Econo setting we consistently get a 2 HR reading. We have also had it where the unit gets stuck on...
this is common, a lot of bosch dishwashers had circuit board recalls. call bosch to see if yours is one. also if you get the cicuit board replaced, ensure that it is programed correctly when it is installed. main reason dishwasher extent time is to heat to a certain temp. bosch will then average out previous cycles and adjust its times. sounds like your not heating.
Nov 24, 2009 | Bosch SHU5316UC Dishwasher
My SHU53 only starts on 2Hr Delay and water is not getting hot
Bosch dishwashers run the heating element directly from the control module, which usually causes the solder joint to go bad.....solution, replace the control module, or take the old one out, and repair solder joint
Dec 27, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Cold water. Water has never been hot since installed.
indicates that the heating element in the unit is non operational ( not connected or burnt out )
Jul 30, 2017 | Bosch SHU5316UC Dishwasher
Dishwasher not drying - Bosch Integra SHU9952
Bosch generally drys through evaporation from hot water rinse. There is a common circuit board issue where a cold solder joint on the heater relay pops.The water does not heat sufficient to evaporate any longer. Consult your manual for self diagnosing trouble shooting codes or go to appliance
If the board connection is the issue I have repaired several, however Bosch recommends replacement only and sometimes supplies the parts free.
Aug 14, 2008 | Bosch SHU5315UC Dishwasher
No water coming in
check water line for kinks make sure water is turned on check water valve
Dec 30, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
778 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
