Prompt to enter setup when started
I use Intel D865GBF mother board with BIOS version BF86510A.86A.0060.P16. When Does I starts my system, it always displays entering setup press F4 to resume. What shall I do to overcome this problem?. Please give me a solution.
  • RABEESH BALAKRISHNAN Nov 24, 2008
    I ALSO DO SO BUT IT ALWAYS ASK SO
  • 94 Answers
Press del to enter to cmos and set to load setup default and select exit and save changes and if happen again replace your cmos battery.
Posted on Nov 24, 2008
HOW TO UPGRADE INTEL 945GCLF MOTHER BOARD BIOS. BIOS VERSION IS "LF94510J.64T.0000.2009.0123.1105" & BIOS SOFTWARE VERSION IS AVAILABLE ON SITE IS " LF94510J.86A.0038.EB " WHEN I...
It seem your current version "LF94510J.64T.0000.2009.0123.1105" doesnt have any BIOS ID's which is required to upgrading. Where '0000' should have any version number.
I recommend using DOS environment when upgrading BIOS, this is the safe way flashing BIOS..so download file LF94510J.86A.0278.BI.ZIP here.
Extract all files on USB flash disk which is bootable flash disk. Run files executable on the command prompt and follow the instructions..
Aug 07, 2011 | Intel Computers & Internet
D865gbf intel motherboard sata hdd compatibility
Check with Intel ... www.intel.com/support ... look up your board, specs, and it will tell you what you can and cannot use.
May 03, 2010 | Intel D865GBF Motherboard
I want to the bios intel motherboard d845PEBT2 place sent me
First be clear, do you want to update your BIOS & if so then go through this first: To identify your current BIOS version, check the BIOS version string:
  1. During boot, enter the BIOS setup by pressing F2.
  2. Check the Main menu.
  3. The 4-digit number after the '86A' or '86I' is the current BIOS version, as in this example: MQ96510H.86A.1663.2007.0319.1957
  4. Press Escape to exit BIOS Setup.
Important:
  • Update the BIOS on your computer only if the newer BIOS version specifically solves a problem you have. We do not recommend BIOS updates for computers that do not need it. You can view all new BIOS fixes in the Release Notes included on the BIOS download page in Download Center.
  • Before initiating a BIOS update, be sure to read and precisely follow the update instructions. You may wish to print the instructions for easy reference.
  • If a BIOS update process is interrupted, your computer may not function properly. We recommend the process be done in an environment with a steady power supply (preferably with UPS).
  • All images in the examples used in the instructions are specific to certain desktop boards and are for illustration purposes only. You need to select the correct BIOS files for your desktop board.
There are up to six methods of updating an Intel® Desktop Board BIOS to the latest version. The number of options made available for any particular board may vary, depending on drive support and BIOS update file size. You only need to use one.
All BIOS update files for Intel® Desktop Boards are available on Intel(link: http://mysearch.intel.com/corporate/default.aspx?culture=en_US&q=d845PEBT2&category=all&adv=0&value=0&searchsubmit.x=30&searchsubmit.y=12).
If simply want to clear the BIOS then either remove the small battery on the MB, wait for a couple of minutes and replace it. Else close to the BIOS chip look for a 3 pin setup on the mother boar with a jumper on two pins Remove the jumper, wait for 10-20 seconds & replace it. That will clear the BIOS.
A word of caution, do not update the BIOS if your PC is working properly. Do it when prompted to,during installing a new software or hardware this message will pop up on the screen.................sodeep
May 15, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Hello sir, the system zone-2 temp., always keeps flashing in red.
It is a motherboard problem. But you can disable that alarm from the BIOS. I would simply raise the upper threshold in zone two from 56 to 60 if I were you. If it still flashes red put it back to 56 and disable it.
Apr 26, 2009 | Intel D865GBF Motherboard
Thanks marked
If you have the user manual for your motherboard you can find there how tor eset the BIOS to its default settings so you won't have that BIOS problem...
Don't forget to rate the solution FIXYA thank you....
Oct 14, 2008 | Intel D865GBF Motherboard
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
Driver
Intel D915 onboard Audio, Video installation driver
Mar 07, 2008 | Intel D915GAV Motherboard
Computers & Internet Logo
471 people viewed this question
David Payne
David Payne
