Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My oven want heat up sometime and sometime it heat and start cook
Model # JGBS23BEA1WH
S. # LT170832P
    Sergeant:
  • 221 Answers
    Genius:
  • 1,550 Answers
Try to provide more information about your problem .
Initially check the breaker is proper .
ALso is door locking properly .
Posted on Jan 26, 2009
  • GE Master
  • 19,396 Answers
Ypu need to check the wiring harness, the heating element , the connections to control board, and also the temperature sensor.
I will find parts and diagrams.
It not cooling
If you're talking about a microwave oven:
[1] plug the mains cord in to the wall socket
[2] switch the socket on
[3] put food to cook on glass turntable, never use empty oven.
[4] close oven door fully until it clicks
[5] set the power
[6] press 'start' or turn the timer-dial,depending on your model.
It will start to cook immediately.
The humming sound is the energy heating the food in timed bursts of power.
If nothing happens or it won't cook, post clear description of fault with problem, make, model.
Hope this helps,
Clive.
Oct 19, 2017 | Microwave Ovens
Tip
DANGER WARNING! Potential Hazard if your microwave was working and now doesn't...
If you have this model microwave and it was working fine, then one day it stopped heating items placed inside there are a handful of different issues that could be the problem. In my case it was intermittent, over a period of a few days it would sometimes work (heat) and sometimes not. NO MATTER if this is what your's is doing or if it stopped heating all together. If you decide to let it dry out, or not use it for a while to see if it was a one time occurrence, or whatever the reason, the first time you put something in and probably for the next 10 times at least (this assumes it starts to work again), make sure you are right there with it while it is cooking. Don't assume you can put something in, go do something and come back when the timer is beeping. There is a chance (as this happened to me) that your food inside will CATCH FIRE! Normal food item placed inside, no metal, nothing different than the numerous times before when this had been cooked but when we smelled smoke we came running. Fortunately it started and finished inside the microwave but that's not a guarantee, it could spread. Play it safe. Never had a problem like this before and never heard of a microwave cooking something until it caught on fire (especially since the time entered for the cook was 30 seconds) but it did.
on Sep 23, 2013 | GE JVM1850SMSS Microwave Oven
I have a double oven kitchenaid natural gas range model KGRS505X. When I cook in the upper oven nothing I cook will brown. Buiscuits get cooked but are still ehite when done. What is the problem?
The top oven not maintaining heat why plenty of reasons depending on age could be a weak ignitor, bad temp sensor, is the oven light on if so oven stops heating after 30 seconds any oven maintaining set point temp will brown and if left long enough burn
Jan 26, 2015 | KitchenAid Kitchen Ranges
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
Mine is a similar problem - light and fan BOTH stay on when the cooking/heating finishes! The door remains closed and the food/beverage cooks. However, when it's finished the light remains on and the
There are a number of interlock switches that the oven door activates when closed, sometimes one becomes defective causing the main fuse to blow in the microwave or continue to run when time is up.
Nov 11, 2011 | Microwave Ovens
Does not heat. It would sometimes cook and sometimes not, until it quit cooking altogether
Sounds like the magnetron shorted out. This is the part that heats the food. Unfortunately, this part is almost more cost than a new microwave so I would recommend just getting a new microwave. If you would rather try replacing this part, you can order a new one from repairclinic.com and find one by searching with your model number. Let me know if you need anything else.
Benjamin
Nov 04, 2010 | KitchenAid KHHS179LSS Convection /...
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
Express cook doesn't heat. Time cook seems to work at least sometimes
Oct 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No fan noise when cooking.
The internal cooling fan is critical. It comes on automatically whenever the oven is cooking.
If the oven is used without its working properly, the magnetron can be destroyed very quickly.
(This of course is different from the hood vent exhaust fan, which you can turn on and off at will)
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
In some models, the motor itself is bad. In other models, it is a bad relay or connection on the control circuit board.
We regularly repair these control panel assemblies for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly (with your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
