Samsung DLP rear projection HL-R4667W Green Screen of Death!!
My parents' Samsung DLP rear projection TV HL-R4667W is about 2.5 years old and has video problems. The TV Guide menu screen, Setup menu screen and audio are perfect. The video from the Air antenna and all RCA inputs (DVD, VCR, AV3) are projected as a kermit green screen, green with vertical stripes, black screen, occassional flickers of source video, blue screen, blue vertical stripes and rarely magenta screen, green/blue vertical striped screen. Does anybody know what component or circuit failed? Thank you!
  • tom_fw_texas Dec 08, 2008
    I have the same problem with a HL-R4667W.  Green stripes with any NTSC video or antenna input.  Also, if I leave it in antenna (or video in) mode the tv shuts off and restarts about every 15 seconds.
    However, it works perfectly with the RGB (Pc) input in all resolutions.  So it's appearently related to the the RF and / or video processing and not the display engine.  I'm just getting into this so if any one knows if that is a seperate pcb or if it's all on one big board it would be helpful.
  • 3 Answers
SOURCE: TV HAS GREEN HORZONITAL STRIPES
Check if this happens in analog inputs ( connect a DVD player or any other component uing RCA cables white,yellow,red ) then check if the bars are showing on digital unputs ( connect using HDMI cable )
if it is just an analog problem - replace analog board
if it is just a digital problem - replace digital board
if it is a problem with both -replace DMD board
Posted on May 24, 2009
SOURCE: pink or magenta stripe across the top of my sony kdf-55e2000
Sony has extended the warranty on the optical block which you are experiencing a problem with until June 30 2010. Read about it here. http://www.agoraquest.com/display_alert.php?alert_id=17
Posted on Aug 18, 2009
vinnyq
  • 157 Answers
SOURCE: i have a red stripe across the top off my tv
This issue is because of a defect in the light engine. The only way to solve is to replace the whole light engine. They usually run anywhere from $500-$2500 depending on the model. Sony extended the warranties for the light engine on certain models that have this problem because of the defect, contact Sony to see if a certain TV had the warranty extended.
Posted on Oct 05, 2009
Testimonial: "thank you "
SOURCE: Hi, I have a Vizio P42.
I had the exact same thing happen in the exact same position. From what I am reading on the internet, my next TV will NOT be a Vizio.
Posted on Nov 11, 2009
ladywinn
  • 5138 Answers
SOURCE: No picture on my Samsung HL-R4667W TV.
Its your Lamp if you have sound and no picture.
CK the lamp Fan make sure it is running.
Lamps Prices depend on where you buy.$85.00 up to $300.00 Look on E-Bay under Electronics/ Lamp number-BP
Mats Electronics has them for $99.00
1-800-628-1118
remove your Lamp and look in middle of it,that will tell you if it is busted.
Posted on Mar 03, 2010
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
Replaced the color wheel on a Samsung DLP
Did you replace the color wheel yourself ? Sometimes you have to remove a small black jumper on the DM module on the light engine and that will remove the greenish but sometimes adjustments also need to be made in the service menu.
Oct 30, 2009 | Samsung HL-R4667W Rear Projection...
DLP HL-R4667W Resolution 1080
notice it states 'hdtv ready', not 'hdtv'! probably need a converter or upgrade module to get 1080p! read the 'gotchas' in the owners manual!
Good Luck!
Oct 08, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp projection tv-when turned on green horizontal lines show up acroos the screen
that is what was happening with mine.  Tech came out and we are not waiting for a new DMB board.  Glad it's under the extended warranty we bought in 2005 (which runs out next month) or it would have cost $500.00 parts and labor.
Mar 17, 2009 | Samsung HL-R4667W Rear Projection...
Samsung HL-R4667 DLP There are about 6 vertical bands (usually all the same color) running top-to-bottom and within these vertical bands is a picture trying to come in. The screen behind the bands is...
needs a DM Board, prity easy to change yourself, if you order one, make sure you give them the version number off the Right side of the TV, will be somthing like SP01, To change - when you take the back off the tv, it will be on the left hand side, have to unplug 3 or 4 connectors, then take the plastic covering off, and it will slide out.
Jan 08, 2009 | Samsung HL-R4667W Rear Projection...
Televison & Video Logo
363 people viewed this question
Top Televison & Video Experts
