Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigerator and Freezer not cooling....
GE Monogram Model #: ZFSB26DNDSS
I hit the turbo cool button, but the express thaw light runs instead. Does my refrigerator need a complete thaw, then start up again? Need some help on this!
  1. my kenmore side by side Model #465825 Refrigerator doesn't cool or and ice maker is'nt making ice.
Posted on Dec 09, 2008
Ge monogram not cooling properly
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 18, 2014 | GE Monogram Side by Side Refrigerator
The freezer isn't as cold as it was yesterday. Waffles are soft and ice cream is like a milkshake. The settings in the fridge at the top: Freezer--said 22 earlier. I put it on Turbo Cool and it has...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 15, 2011 | GE Refrigerators
Ice sheet forming on bottom of freezer. GE Monogram with top refrigerator and bottom freezer
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 21, 2010 | GE Monogram ZICS360NRRH C... Bottom...
Refrig is not cooling. It is a GE Monogram. Freezer is at a normal ref rig temp.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 28, 2010 | GE Refrigerators
Ge monogram refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
erwfj,
May 31, 2010 | GE Monogram ZICS360NR Bottom Freezer...
GE Monogram Freezer wont defrost
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 30, 2010 | GE Monogram ZDI15C Automatic Icemaker
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
Express Thaw comes on when refrigerator door is closed
We have a GE Profile side-by-side refrigerator which we purchased in 2002, Model PSS25NGNACC. Today we had a repairman come to investigate why the Express Thaw 3lb. light was on and could not be shut off. If shut off, it came on again when the door was closed and reopened. The repairman called GE and learned that this light was an air filter change indicator which turns on at some interval (2 years, they said, although we don't remember ever seeing this before). The air filter involved is for the interior of the fridge and is not critical. GE said that newer master control boards have this function disabled, since people rarely changed the filter and GE no longer makes them. I have read our user manual cover to cover and find nothing on this filter. I guess we just have to pay the $70 dollars to have someone come and call GE to figure it out. But, enough of that. To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps:
Adjust Freezer Temp (Warmer)
Express Thaw
Adjust Refrigerator Temp (Colder)
Lights and functions should return to normal.
Feb 11, 2010 | GE Refrigerators
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
597 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
