Question about Intel Motherboard
I have intel 845 chipset gigabyte motherboard, no display problem
My system is running buy is not giving any display, processor fan is running, hdd indicator in not turning on, i am not understanding whether my system is not booting or whether not giving display, what should i do plz help me...
  • 94 Answers
First turn off your computer or unplug it open your remove the memory card to the right side of the mother try to clean memory put it back again to the slot but be carefull put it properly and switch you computer
Posted on Nov 24, 2008
Sound output is not available now in my PC, having gigabyte Motherboard and intel processor.
You have Intel chipsets and Realtek sound. The gigabytes link only seems to have audio and lan drivers here;
http://www.gigabyte.us/support-downloads/download-center.aspx
Outlined info
1-Product Catagory-motherboard
2-By Socket-Socket 775
3-By Chipset-Intel 945GZ
4-Product Model-GA-945GZM-S2
Click search and enter you o/s and it will list your updates.
Other updates canbe gotten here;
http://downloadcenter.intel.com/
You can ckick on "Run Intel Update Driver Utility" and Intel will scan your system and suggest and provide updates or, you can search for individual downsloads
1-Product Family-Chipsets
2-Product Line-Desktop Chipsets
3-Select Product Name-Intel 845 Series
A new window will come up to choose your o/s
You may want to check your operation first by clicking "start", then click on "control panel". Find and click on "device manager". Click on box with + next to "sound audio and game controllers". Do you see a warning ?, !, Or a yellow triangle? click on that and follow proceedure. Right click on your device and in the list you should see "disable". If you see "enable" click on that and exit.
Ther should be a speaker icon in your taskbar at lower right of your screen. Right click on it, then click on "open sound mixer" and adjust volume.
Apr 02, 2011 | Gigabyte GA-945GZM-S2 Motherboard
I want to upgrade my CPU capacity from 1.2 GHZ and want to know my motherboard so much support??? my motherboard is GA-8IDX (845 chipset)
If you go to CPU-Upgrade.com, you can see all of the different processors that are compatible with your motherboard:
http://www.cpu-upgrade.com/mb-Gigabyte/GA-8IDX.html
The ones highlighted in pink are not supported for your motherboard, the ones highlighted in orange may or may not be, and all the ones in white are compatible with your motherboard. It looks like you have several high-end options, up to 2.8 GHz.
Feb 13, 2011 | Intel Gigabyte GA-8IDX 845 AGPset P4...
I need display driver for my pc i am using intel 845 mother bpard i need driver for windows vista
If you are using Intel 845 Chipsets motherboard, FYI, 845 chipsets family does not support OS Vista, you will not be able to get any Vista drivers support from Intel!
You can read this thread from Intel @ http://www.intel.com/support/motherboards/desktop/sb/cs-008326.htm
Aug 04, 2010 | Intel Computers & Internet
Hdd detecetion proublem on 845 motherboard
845 chipset dont support sata devices and this is common problem that if unsupported device is forcefully bieng tried to work its goona happen sata support started from865 chipset u are lucky that ur hdd is getting detecting
Jun 11, 2010 | Computers & Internet
Connecting sata hdd on 845ge
Directly you can't, the chipset on that motherboard doesn't support SATA. You will have to buy a PCI SATA card and plug the disk in it.
May 04, 2010 | Intel 845GE Motherboard
Problem with pc
You probably need to check the cooling fan setup ( some motherboards give the control on the task manager or a sperate software to control it) This seems to be a problem of overheating which might have started after the installation of new ram.
Feb 28, 2009 | Intel Computers & Internet
Want to replace noisy fan for ASUS Intel 845 Chipset P4B Motherbo
This should give you time to find a new fan
Remove paper center from fan and put a small drop (I mean small) of light machine oil on the bearing then replace paper center.
This should get you out of trouble for a few months at least.
I have done this with at least 8 fans in the past some never needed a new fan
Dec 18, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Maximum HARDDISK CAPACITY FOR Intel 865GV motherboard
Yes, your board will support 320gb. I am not aware of a limit to how many gigabytes you can have per computer. I currently have 1.5 terabytes. 1500gb.
Apr 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Intel Motherboard Logo
176 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
