Question about Acer Aspire 5500 5570-2609 Laptop
Projector can't open went connected to acer aspire5570.
The adapter of projecter has been connect to acer,but the skrin can not detected any connected from the projecter..why?
  • 2 more comments
  • ayu_ucop88 Nov 24, 2008
    what is the special function key to connect to the projector ?
  • badu11111111 Nov 26, 2008
    la orbicam no responde
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    it will be on of the f keys,f5 of f8,there will be a rectangle icon with a vertical line on either side of it..u need to press the function key (fn) and the f5 or f8 key..doing it twice will let u have display on both laptop and projector..hope it helps..
    the image should help u..please locate the f key with icon i varies on different info if it works,,
  • Lalit Varadpande
    if its properly connected use either the special function key to connect to the projector or right click on empty dektop..look at graphic options..output to..
VGA-HDMI connection fail on Acer projector using adapter
You don't say whether or not the "adapter" is simply a gender-changer, or if it actually converts the digital signal from the HDMI port to an analog one for the VGA port. Some monitors have both analog and digital input capability and can automatically adapt to the the digital signal, even if applied to the VGA (analog) port. Other devices are not so smart and need an actual digital-to-analog converter style adapter.
Jul 06, 2016 | Acer XD1170D Projector
How do I get the drivers to download on my toshiba laptop
Ensure the projector is plugged in and on BEFORE the laptop is turned on.
The laptop should then detect the newly connected display and windows will enable it for you.
You may need to open the Display settings in windows control panel, if the display needs to be set as a mirrored or extended desktop.
Oct 16, 2014 | InFocus LP 435Z Multimedia Projector
Hi, i just getting a Projector, but my laptop - acer aspire 5935G+winXP unable to connect it thru the HDMI, VGA no problem
When connected with HDMI, right click on your desktop and select "screen resolution". When it opens, select detect. Does the computer find the projector?
Apr 19, 2014 | Computers & Internet
I am using Acer Aspire 4736z laptop with Windows 7 Home Premium. I am unable to connect the laptop to external projector. I have tried all basic troubleshooting steps but nothing has worked. I...
The screen resolution on your laptop may be set too high for the data projector. Try reducing the laptop's screen resolution down to 1024 X 768.
Jun 02, 2011 | Computers & Internet
TravelMate 3270-6569 (LX.TH706.051) PC Notebook: My acer travelmate 3270 is connected to a sony dat...
Try holding down the Function key (Fn), then pressing F5. Wait a few seconds. On most laptop, each press of the F5 key will toggle between laptop display only, projector only and Dual (same image on both - my favorite).
You'll probably see a little Monitor-shaped icon on the F5 key. It's possible it's another function key - on Dells it's usually F8.
Aug 02, 2017 | Acer TravelMate 3270-6569 Notebook
Picture Projection
The default to enable the external VGA is Fn+ F8, it toggles between LCD, LCD + External and External only.
You may need to wait up to 15 seconds for the switch to occur.
There also may be issues with the resolution of the projector and or detection if using some type of adapter in the connection.
Resolution of the projector is 800 x 600, so you may need to reduce the system resolution to that too.
Feb 17, 2010 | Dell Inspiron 2200 Notebook
Cannot connect acer aspire one to projector. it's first detected when netbook is booting up but the connection dispappears (no input on projector) when the computer is fully on.
It should be a keyboard toggle to switch display to the projector, usually Fn + F5, sometimes you have to tap the F5 key a couple of times for the display to switch over.
Good luck
Jun 19, 2009 | Acer TravelMate 2300 Notebook
ACER Aspire One AOA150-1635 and Sharp XR32-X projector
you need to connect it with VGA. then enable the 2nd monitor
now you should have a wallpaper on the projector, you can drag objects to it by draging them out from the screen.
if you don't have the 2nd screen option. Then hold down the blue FN button and then tap F5 see if the picture comes, the FN + F5 will swap around with the outputs.
Feb 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Projector cannot detect my connection to my laptop
try hitting function 8, had the same problem giving a presentation and that took care of it.
Feb 12, 2009 | Taxan U6-132 Projector
Acer Aspire 5500 5570-2609 Laptop Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
