Question about Zanussi FJS1225W Front Load Washer
What is E 40 on Zanussi Turbodry 1200?
What is error 40 on Zanussi Turbodry 1200? During the washing, some water came out from the washer.
  • dazthx3 Dec 31, 2008
    My zannussi jetstream 1400 washer dryer wont start. just plumbed it in and it all turns on etc but when you press start it comes up E40 code??
    it was working fine until now when we moved house recently it was working fine.
  • 17 Answers
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Posted on Dec 17, 2008
My washing machine is zanussi turbodry 1200.Is there an instruction manual I can download?
You should be able to get one from zanussi by going on to there website
Dec 15, 2017 | Zanussi Washing Machines
Zanussi jetsystem turbodry 1600 wjs1665 w is not heating the water
More than likely the heater element has failed.
This is located at the rear of the washer drum.
It means removing the rear half of the cabinet to access it.
Mar 29, 2010 | Zanussi ZWF1430W Front Load Washer
Stoping under process on every step from begning to ending
its very common for front load washers to have the water pump to freeze up.
ever washed something with sand or little rocks or rubber bands?
flip the washer to the side, then locate the water pump. take the filter and the hoses around the water pump. sometimes the water pump too, to make sure that the fins on the water pump are free and not stuck. put everything together and try the cycle. when the water pump is stuck it will cause the error and will not go into the spin cycle.
Aug 14, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Jun 24, 2009 | Zanussi ZWF1420W Front Load Washer
Zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanusssi jetsystem turbodry 1200
clean out filter, door bottom right, unscrew filter and clean it
Aug 02, 2008 | Zanussi IZ161S Front Load Washer
Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 08, 2008 | Zanussi FJS1225W Front Load Washer
Door wont open
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Dec 23, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
933 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
