Question about DCS CS-364GL Gas Cooktop
Center grill inoperative
PRSE 364GL - none of the relays (K1 - K4) energize (not sure which relay controls the grill) when the grill knob is turned on. Could this be a relay or safety valve issue?
0 characters
1 Points
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
I have bosch pgl985uc burner problem. The center burner will not stay lit. Seems other have had this problem. I ordered all new thermo-couplers. Installed, since Bosch changed them to a new part number...
If The Burner lights and stays lit as long as the knob is depressed, but goes out after the knob is released then there is a failure with the thermocoupler or the valve itself. The thermocoupler can be tested once removed from the cooktop - as follows
Heat the tip on the thermocoupler with a match or lighter and measure the electrical connection (other end) with a voltmeter - it should read about 15 mV or slightly more with in a few seconds. If no voltage is read then the thermocoupler is faulty and should be replaced.
The valve coil can also be tested for continuity at while the unit is disassembled. If no continuity is found the valve is faulty and should be replaced
The small voltage created from heating the thermocoupler energizes the coil in the valve which in turn keeps the gas turned on while there is heat at the thermocoupler.
Some units actually reignite the burner if the heat is lost and the control knob is in the on position.
Hope this helps ....
Dec 14, 2013 | Bosch PGL985UC 36 in. Gas Cooktop
I have a 6 burner range top. When I turn on 5 of the six all 6 spark as they should and the correct one lights. When I turn on the left front knob none of them spark and it will not light, but gas does...
The problem is the burners switch the the single burners has failed, this will cause is not to fire the module and ignite the burner. I would replace just that burner switch to correct the problem. When you call for parts, make sure you have the complete model number and possible color of that burner switch needed. They make or have available switch that are sold by color, so color may be needed for this model.
I hope this helps.
Sep 20, 2013 | Viking 37 in. VGSU161 Gas Cooktop
Middle section ticking sound with sparking as if trying to ignite even though knobs
Try using a pair of pliers and pushing down as you turn first counter clockwise as if you are turning the gas on then back clockwise till it won't turn anymore. If it's still trying to ignite see if its the oven or make sure that its the burner that's trying to ignite . I''m not a appliance person just a home maker so if it were me and none of those things work turn off the gas to the stove unplug the power to the stove and call the gas company or appliance center. One thing though some of those type of knobs are two parts like they have to be pressed down to turn on the gas. Or the have to be set in a certain position to engage the ignite switch. If you know a little about wiring look at the switch and check the wires. But make sure before you do anything that there is no gas on.!!!
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
Why won't my amana smoothtop cooktop turn off. the know will not turn it off.
It's apparent the power relay - or the knob itself is faulty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | Amana ACT101E Electric Cooktop
Ignitor wont shut off after burner is lit- keeps clicking
hi.gud day...tnx for gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
Sep 15, 2009 | DCS CS-364GL Gas Cooktop
The ignitor sparking will not stop in after the
when you turn the knob or push a switch is going to the on posicion so that means that the switch is stuck in one of the knobs , you just have to see witch one is stuck
Jun 18, 2009 | Wolf Range 30 in. SCB30C Gas Cooktop
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
DCS CS-364GL Gas Cooktop Logo
19 people viewed this question
Top DCS Cooktops Experts
Lawrence Oravetz
Are you a DCS Cooktop Expert? Answer questions, earn points and help others
