-   is there a smart option in the setup? I have a similar problem..hardrive crashed..Screen shows..drive failer imminent.press F1 to continue..F1 leads to the screen which shows windows startup options (i.e. safe mode, safe mode with netwrk and normal) but selecting any option does nothing..and the computer shuts down..
Any help will be appreciated!!
ps. I tried running the OS cd for the recovery option..but I am not sure how to continue with that..bunch of commands..but nothing that seems to help with recovering any data?
-   Can i rock a 250gb hard drive
-   Guest
Feb 22, 2009
-   i have the same smart failure problem and it says to press f1, i tried pressin f2 but didnt do anything....helpp????-   d90shooter
Jan 20, 2009
-   I had the same problem and can add that in my case, the hard drive was fine, the laptop lost the ability to recognize any hard drive. All of my information was still there.
Does anyone have advise on what component(s) can be changed on the motherboard to resolve access to the harddrive?
glen-   glcraft2002
for a temp fix enter setup ,disable s.m.a.r.t function then reboot , should be fine for awhile at least long enough to back up all you need ,till u replace the drive, or run it til it dies.could be a day or years.
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area...
(More)
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area but
webcam in compaq presario CQ60 not working after installing vista, i installed drivers from compaq...
(More)
webcam in compaq presario CQ60 not working after installing vista, i installed drivers from compaq itself but still webcam not working.
when i perform the memory test through bios setup the 10008 no warrenty id error code in the hard...
(More)
when i perform the memory test through bios setup the 10008 no warrenty id error code in the hard disk is displayed
My DVD driver is either corrupt or missing for my Toshiba Satellite running vista. Code 39. Where...
(More)
My DVD driver is either corrupt or missing for my Toshiba Satellite running vista. Code 39. Where can I download drivers from. This ocurred after attempting to install Norton internet security 2010
S.M.A.R.T HARD DISK DRIVE ERROR PRESS F1 TO RESUME shows on screen.
When i push F2 instead, i enter the bios. then push Esc...lapto reboots.
The hard disk makes buzzing sounds now.
I guess it's time for a new pc. I think I'll go with applenext time.
