Question about SanDisk Sansa e250 MP3 Player
Sansa mp4 player startup hang
My sansa e250 mp4 player hangs on startup while showing "refreshing database " ...and so it also is not being recognise by my computer..lz telme exactly how to fix it
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
While switching on the mp3 player... it been hanging.... refresh database error
Reset the sansa by pressing on the reset on the device , this is usually a small pin hole through which an office pin can be put in and pressed.
Now connecct your player to the PC and scan for virus, copy out all the files and format, the reinstall safe files.
The player will work fine.
Sep 01, 2010 | SanDisk Sansa e250 MP3 Player
Sansa ipod e250 is hanging
With no response in a month, I assume this is no longer a problem.
Mar 04, 2010 | SanDisk Sansa e250 MP3 Player
My Sansa e250 no longer functions when switched on
what can i do if my sansa e250got problem just wen i turn on thers always say refreshing database...... then he hang... and no i con
Oct 05, 2009 | SanDisk Sansa e250 MP3 Player
Sansa view is hanged at Refreshing Desktop
i have a privious problem like this no solution i give it in to service center. it a problem with the memory
Jul 29, 2009 | SanDisk Sansa e250 MP3 Player
Refresh Database
Go ahead and do this, in case the DB is corrupted:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 16, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database hang up and screen turn black
Mar 08, 2008 | SanDisk Sansa e250 MP3 Player
"refresh database"
try formatting the hole mp4 *the musik partition only!!* or
try to use the recover mode and reinstall the hole mp4
more information u finds on google....
Jan 16, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database
I by mistake formatted My mp4 there misssing my data
Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 screen is stuck on refresh database
Press the "lock" button to where the Orange is showing. Then press the record button on the left side of the MP3 for a bit. Try this several times. I did it twice and it worked! M.P.
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e250 mp3 player database refreshing problem
I cant really help you with the reboot problem, but youy should have never taken the backplate of, that voids the warranty so that you can't return it.
Dec 25, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
140 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
