Question about Sony Playstation 3 (PS3) Console
No sound from hdmi cable
I have just turned on my ps3 after it being unused for a few weeks. it has been working fine untill i just turned it on i have no sound from cable at all. i connect cable from ps3 to tv and tv sound cable to my home theatre system. suddenly no sound from cable ive tried restore and audio settins nothings working, everything goes fine when connected throuugh normal cables but nothing through hdmi cable, i still get picture though. ive tried everything. please help :)
    Problem Solver:
  • 34 Answers
PS3 is The amazing device by sony but it has some common problems like sound but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Feb 27, 2009
No video signal using HDMI cable.
This sounds similar to my Vizio's second HDMI port; they sometimes become finicky after a while. You may have to just adjust and wiggle the end of the cable inserted into the TV; if it works, then make sure you don't even slightly touch it or else it'll lose signal again. If you have any other ports, try them instead; otherwise the problem may eventually get to an unusable point. You will have to have the port repaired or the TV replaced.
Jan 30, 2018 | Toshiba 47ZV650U TV
I have a 47 lg lcd tv bought in 09. When i use hdmi for xbox 360 i get picture and sound but with ps3 no pic no sound. I just bought a sony bluray and get pic but no sound. I bought a lg bluray and get no...
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Nov 08, 2017 | LG 47LF11 LCD TV
PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
PS3 wont work with AJAX after using HDMI cable
ps3 does not reset the video automaticly you have to reset it yourself any time you go from one mode to the other
to do the vid reset just hold the power button when in standby(red light) untill you hear second beep then release
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
89 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
