Question about Motorola Mobility ROKR E6 Smartphone
Mpkg software installation
I want install mpkg(to install softwares) in my phone
replace with .system folder in memory card
the mpkg will appear as a smily yellow symbol--it cannot install any .pkg files
please help me
  • 1 more comment
  • Anonymous Jan 01, 2009
    i have the mpkg english version 3.1 but its not getting install on my rokr e6 .....how can i install this mpkg software
  • boopathy16 Feb 10, 2009
    yes
  • pratimrox Mar 08, 2009
    hey i hv installed mpkg installer on my phone.bt it cant open any *.pkg file.plzsum body hlp me.
Hi
help me
i need mpkg software for motorola A1200 becuse i want instal *.pkg files
Posted on Dec 03, 2008
To use a rar file, you download it, then use the tool to unrar it before copying the uncompressed file(s) to the SD card in your phone.
How to Copy Files To/From Your Phone
On the A1200, go to Application Launcher-->Setup-->USB Mode and ensure that “Mass Storage” is selected
Plug in the cable that connects the phone to the USB port on your PC.
Open Windows Explorer and ensure that you have “Show hidden files and folders” turned on in Explorer (Tools-->Folder Options-->View-->Show hidden files and folders)
You can now use Explorer to view the folders on your SD card on the phone. The SD card will probably be drive E: or F:. The root folder of this SD card shows directly under the Drive in Explorer – but its full path is /mmc/mmca1/ (i.e. if you copy something to the root you are copying it to /mmc/mmca1/).
You should see a folder called .system under root. If you do not see it then check you have “Show hidden files” on (see 3 above). You are only able to view/edit files on the SD card – this method does not permit you to view/edit files directly on the phone (which is why you need installer programs like MPKG and linloader to install programs on your phone).
You can now copy/cut and paste files to and from your PC to the folders on your SD card.
Unplug the phone when done. (Before unplugging, you should always use the unplug or eject hardware facility. This will ensure integrity of the filesystem on the transflash card).
Wait a couple of seconds then you can then use File Manager under Application Launcher on your phone to view these files.
Posted on Feb 08, 2009
Mpkg app not showing in my phone..:( what to do? plz help
Posted on Apr 18, 2011
Bluetooth of my phone is not working properly. When i try to switch on bluetooth then a massage is shown on screen " unable to perform bluetooth operation."
Try formatting the phone.This will help to solve this problem.If still the problem persists then update the software from any NOKIA CARE
To format nokia 3230 mobile please follow the below steps.
Please download the software called as 'Psiloc System Tools'.
You can download the system tool software from below website
http://gallery.mobile9.com/f/1047847/
Install it in your phone memory.DONOT install in your memory card because we will be removing the memory card.
Remove the memory card
Open the installed software.
Go to 'TOOLS'
You will find the option called as 'format phone',select it.
It will ask for confirmation, confirm it and it will format your phone.
It will restart while formatting and this process takes several minutes.
Once the mobile is started your mobile is formatted.
NOTE: Formatting will delete all your content from your phone memory.
Thank you
Oct 05, 2010 | Nokia 3230
Where can i get motorola e6 theme installer software
1- install .lin Loader on ur phone
2- as it is a pkg file so u shud have mpkg to installer loader
3- then look out for the .lin file in the themes folder
4- put ur stylus or hand on it for 3-4 seconds
5- after this select open with and then select loader
6- wait for 20-30 seconds and then restart the phone
http://www.mobileheart.com/cell-phone-softwares/1136-Motorola-ROKR-E6-Software.aspx
Apr 01, 2010 | Motorola Mobility MOTOROKR E6
How to install iphone theam with motorokr E6
Installing iPhone.lin Theme *Requires LinLoader installed Installing MPKG Download: http://www.mediafire.com/?4tcyfw0mqtz 1. Unrar the file. You will see it consists of a folder called .system. 2. Plug in the phone, then use Windows Explorer to copy the entire old .system folder from the SD card to a safe place on your PC (so can recover if necessary). [If you can not see the .system file then you do not have ?View hidden files? on]. 3. Copy the entire .system folder from the rar file to replace the one on your SD card. 4. Unplug the phone from the PC and restart it. You should see a MPKG icon under Application Launcher on your phone. 5. You do NOT run this program by clicking it - rather you open files with extension *.pkg by holding the stylus on the file until a small menu displays. Select ?Open With? and select MPKG. [If you have already installed some programs on your SD card before installing MPKG then you should uninstall then before doing the above otherwise you will not be able to access them anymore (phone doesn't find them). You can reinstall them when complete] Installing LINLOADER **MPKG must be installed** Download: http://www.mediafire.com/?bfyzlydrdmw MPKG must be installed first as you need mpkg to install linloader. 1. Download the loader_A1200.pkg file from above 2. Copy the file to the root folder of your SD card (Make sure extension says .pkg - not .mpkg) 3. Unplug the phone from the PC then use the phone's File Manager to find the file. 4. Hold the stylus on the file until a small menu displays. Select ?Open With? and choose MPKG. You should hear a bell indicating the program has loaded. 5. Turn the phone off and on and you should see a Loader icon (a yellow smiley) appearing under Application Launcher. Download: http://www.mediafire.com/?5zynyynywty 1) Download the theme 2) Extract to desired location ( desktop etc ) 3) Drag and drop "themes" folder into memory card root 4) Unplug from computer, go into File Manager and find the iPhone.lin file 5) Tap with your stylus and hold it, in the context menu, select " Open With" 6) Select Loader ( has a smiley face icon ) 7) Wait 2-3 minutes ( just to be safe, since installing theme is the easiest way to brick phone ) Cool Restart the phone( the iPhone theme shutdown screen should show up ) 9) You're done 10)Run default.lin (included in this theme folder) to revert to default before running another theme
Nov 11, 2009 | Computers & Internet
Some time ago i encrypted files on storage card. one day i formatted the phone. now all files on the memory card are locked and the phone is not reading and even showing the files and folders. even...
Hi..
can u be more specific and tell me wht software u used to encrypt these files.
How ever try this.
Re-install tht encryption software, as encryption file which that software has stored details are saved in the local hard disk, so once u get it installed u can decrypt it easily.
This may not work if u have recently formatted ur PC OS .
Hope it helps u
Regards
Sep 10, 2009 | HTC P3300 Smartphone
Themes settins
I have three skins on my SD card and have never had a problem installing or uninstalling them and you don't need linloader thats where the problem is most of the time....the problem being that some people ran linloader twice and bricked there phone but if you follow the instructions I am about to give..you will be fine....don't keep more than three skins on your phone though..idk why I just heard that and I follow that...i think its because it may fill up mem..idk..but here are the instructions
1.Get/install mpkg loader
2.Install skin installer & splash installer from DL sec.(hold name OPEN WITH MPKG)
3.Make file named themes on mem card
4.Put theme in the theme folder you just made
5.Install .pskn file(hold on name OPEN WITH SKINS)
6.NOW IF YOU WANT WHILE USING YOUR PHONE explore theme folder you have(i-phone/silver skin) in this folder will be a number of files .skn/.pskn/etc... But IF there is no phm file there will be .jpeg/.gif files just rename the .gif file to phm.
EXAMPLE
i-phone.skn
i-phone.pskn
on.gif>>rename>>>on.phm>>>>OPEN WITH SPLASH
Jul 31, 2009 | Motorola Mobility ROKR E6 Smartphone
How to install themes for motorokr e6 with .10p firmware
Heres how you can install iphone theme on your rokr :
Installing MPKG
Download: MPKGinstaller
2. Plug in the phone, then use Windows Explorer to copy the entire old .system folder from the SD card to a safe place on your PC (so can recover if necessary). [If you can not see the .system file then you do not have “View hidden files” on].
5. You do NOT run this program by clicking it – rather you open files with extension *.pkg by holding the stylus on the file until a small menu displays. Select “Open With” and select MPKG.
Jun 10, 2009 | Motorola Mobility ROKR E6 Smartphone
Cant Install Software because of Security
try to format your mobile and backup of memory card and then format your memory card default code is 12345
*#7730#or *#7780# download compatible themes from zedge.net or ownskin.com
Apr 21, 2009 | Nokia 6680 Handheld
Lost and Huge garbled files on Memory Card
This can be a problem with the conflicting device & memory card, or a problem caused by a pocket pc software using the memory card as it's first storage area. You can recover the software folders that can be read by your PC by simply transfering them, and some folders maybe cannot be read, so you'll have to reinstall them. But first, I'll advice you to format the memory card within your PC. Although it'll work for some time, I think you'll encounter the same problem again with the same memory card. I think you can try another brand's memory card, and also you can try to install most of the software used by windows constantly to your main memory, and others like games to your memory card. I hope this will help.
Apr 20, 2009 | HTC P4300
Plz tell me ffrm where i shud download motorockr E6e themes(site..........plz?)
hello dear.......... installing themes on the E6 can be a tricky business and sometimes fatal for the phone. you need to install MPKG installer to do this. for the details on this visit http://www.mototheme.com/Howto.htm. But i strongly recommend that you dont try to install any theme on E6 cause the version of linux EZX which E6 is based on has its own shared memory for using themes. if the newly installed theme exceeds the memory capacity of the phone, your phone will permantly hang and wont do anything. it wont even switch off normally. you will have to take out the battery from the phone. on restarting ur phone, if it hangs again on the motorola splash screen then consider your phone a dead machine. then the only way to bring your phone back to life is by flashing ur phone and installing a new software on it......... which is quite a headache. still if you want to do it. then do it!!! its ur phone brother
Dec 10, 2008 | Motorola Mobility ROKR E6 Smartphone
HTC P3400 Memory Card data corrupted!
micro sd memory card isnot fromating my pc
Nov 10, 2008 | HTC Touch P3450 Smartphone
Motorola Mobility ROKR E6 Smartphone Logo
1,070 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Motorola Mobility
Motorola Mobility
David Payne
David Payne
AJMAL KHAN
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
